  • Guests: 35
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Stereo Audio amp
Andyman
Tue Sept 23 2008, 06:10PM Print
I pulled two of these ICs off of the audio section of a tv board:
UPC1188h
It looks like each one is a single channel amp, and since I have two, I thought I'd build a simple amplifier.
At the bottom of the datasheet, theres an "Application Circuit". If I build 2 identical boards according to the schematic, are there any issues I might face? Also, how well-filtered does the transformer/power supply have to be?
Tue Sept 23 2008, 06:48PM
Just the usual things to look out for;
- Adequate power supply capacitance for low ripple voltage, much better if regulated.
- Adequate current/power available from psu.
- Earth loops causing HUMMMMM pickup
Tue Sept 23 2008, 07:07PM
I would try that circuit. Also go and check Link2 It is a nice forum about audio.
Andyman
Tue Sept 23 2008, 07:53PM
Now, for the power, does the transformer I use have to be a center tapped one? The max voltage on the IC is 24 volts, so I'm going for ±22 volts. If I use a center tapped xformer, does the ±22 mean each winding is 22 volts? I guess what I'm asking is if the ±22 means +22 AND -22 for a total of 44 volts or +11 and -11 for a TOTAL of 22 volts.
Also, where would I replace a resistor with a variable one for volume control?
