  • Guests: 47
Hanzie (31)
badger (52)
h3X (40)
01/10 Hanzie (31)
01/10 badger (52)
01/10 h3X (40)
capacitor charger
big5824
Sun Sept 21 2008, 08:12PM Print
I'm in need of a circuit to charge my 60v 90000uf cap bank from a 12v source, and after looking at this capacitor charger, i changed the design and values slightly and came up with this circuit
Can you guys see any problems/possible improvements? Im planning on the diode, mosfet, and inductor all being rated to 100v 5A minimium, do these values sound ok?
thanks
matt
FastMHz
Sun Sept 21 2008, 08:50PM
FastMHz Registered Member #179 Joined: Thu Feb 16 2006, 02:08AM
Location: Hagerstown, Maryland - Close to Prime Outlets
I'd use a small inverter myself. Cheap, and reliable.
youngcoilgunner
Sun Sept 21 2008, 09:27PM
youngcoilgunner Registered Member #1633 Joined: Tue Aug 12 2008, 04:21AM
now, im not to savvy about amplifiers or comparators, but don't they need both a positive and NEgative voltage feed?(like a voltage that is below ground)
big5824
Mon Sept 22 2008, 04:44PM
i havent used them too much so im not sure youngcoilgunner......can someone clarify this?
youngcoilgunner
Tue Sept 23 2008, 03:46AM
i myself am using a cap from the voltage divider output to the base lead of a 2n3904, which actuates the charging/discharging. seems to me like it would be easier and simpler
