  • Guests: 18
GhostlyFigures (36)
10/06 Ivan Kalafatic (17)
10/07 Pyromaniac (34)
10/07 Wavetuner (76)
Mysterious MOSFET/IGBT deaths
Sun Sept 21 2008, 10:41AM Print
Post any of your mysterious transistor deaths here. By that I mean "cold" deaths, when the device was operated well within its safe operating area. Maybe we can find an explantation for these deaths.
While designing the demo Jacobs ladder, I was operating a flyback transformer with halfwave doubler on the output. I was using 22A MOSFETs in halfbridge powered from 330VDC, driven by a GDT (22ohm turn-on gate resistor, turn off shorted by antiparallel diode). It was putting out approx. 300W of power, when one of the transistors died cold, I guess with ~10-15A peak current.
The gate signal was clean with minimal deadtime, and clamped by 18V zeners.
I have no idea why it popped.
Do you think that a RC damper on the bridge output gives any advantages?
Will
Sun Sept 21 2008, 11:59AM
Will Registered Member #57 Joined: Thu Feb 09 2006, 05:28AM
Were the FETs you used always handled with proper ESD handling precautions?
I've had some cold deaths before and came to the conclusion that they were ESD damaged.
Sun Sept 21 2008, 12:19PM
Will wrote ...
They weren't handled with any special precautions, but considering that the device itself has a few pF at most of self capacitance and the gate is a few nF, it should survive several kV ESD discharge no problem.
I think the ESD becomes a problem for sensitive components (when talking about FETs, small low power/RF ones)
aonomus
Sun Sept 21 2008, 02:11PM
I recall that testing IRF640 MOSFETs by hand using the diode test function on a multimeter showed 2/10 of my new mosfets had an abnormally high (relatively speaking, 0.1-0.2 compared to 0.0 average) forward voltage. I put those two parts in a separate portion of my MOSFET storage in anticipation of failure, fortunately they were $0.60 a piece so I'm not out much.
Mon Sept 22 2008, 12:10AM
It was probably a voltage related failure when running 330V bus.
Mon Sept 22 2008, 09:37AM
Steve Ward wrote ...
They were 500V FETs so I don't see a problem here.
ragnar
Mon Sept 22 2008, 10:33AM
Dr. Kilovolt wrote ...
500V / 330V, 22A / 10A, I doubt this is within the SOA. Do you have an oscilloscope?
rp181
Mon Sept 22 2008, 12:39PM
wow, coincdence, i was going to post a thread. My IGBT is being used for a boost converter, 14v ~3A in. The IGBT is fast, 600v 60A. The IGBT doesnt burn, but it gets really hot fast. Ive used this IGBT for a converter before, and it didnt even get warm. Last time it did this, i was using a normal (not fast diode) diode, when i replaced it it works fine. I replaced it with a ultrafast piece, any other reasons this could happen?
Mon Sept 22 2008, 02:28PM
Matt Bingham wrote ...
Well the device will never see 330V at 10A cheesey It does see 330V with near-zero current or 10A @ forward voltage drop (few V at most).
Edit: Well, it DOES see 330V@10A at the turn-off transition but this is just for a few tens of ns, the device is rated at 88A peak (iirc).
Yes I do have an O-scope, but it always goes funky around switched circuits (displays enormous spikes at the transitions) and often gets "overloaded" so I can't see anything at all.
GeordieBoy
Mon Sept 22 2008, 06:06PM
Really? Most oscilloscopes will round edges and suppress narrow spikes by limiting dv/dt if their bandwidth is insufficient to faithfully reproduce switching waveforms.
If you are seeing enormous current or voltage spikes _AND_ have "unexplained" device failures the first thing to do is to get a decent storage scope and set of probes so you can see what is really going on.
-Richie,
PS. Always ensure that the scope probe ground clip is attached to a ground point in the system under test that is as close as possible to the voltage being measured. This minimises "ground bounce". At very high frequencies (or when probing noisy flyback converters!) it is best to un-clip the flying ground lead from the probe and solder a ground pin to the earthed sleeve around the tip of the probe to minimise the area in the measurement loop. I have found this method very useful for testing off-line flyback PSUs when using properly compensated probes with a decent DSO.
