  • Guests: 30
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Core dissipation question
Sat Sept 20 2008, 03:51PM Print
Is it true that when I double drive frequency and half the number of primary turns on a transformer, the core dissipation will be 4 times greater?
Mon Sept 22 2008, 08:55AM
Core dissipation goes in two parts: hysteresis and eddy current losses.
AFAIK, eddy current losses are "I2R" in nature, so they increase as the square of the flux density. Thus they shouldn't be affected when you double the frequency and half the turns, since this leaves the flux density constant.
Hysteresis losses are proportional to frequency times flux density (or flux density squared, I forget) but in either case they will double, since you assumed flux density to stay the same.
So the total core loss could almost double, if it was mostly hysteresis to start with.
Ferrite datasheets often show a graph of the maximum allowable flux density as a function of frequency. It's limited by heating due to core losses, so you can probably treat it as a line of constant core loss. So maybe to get a more exact answer to your question, you can look at this line and see if it's an inverse, an inverse square, or whatever.
