  • Guests: 63
Got the secondary off my MOT, but...
lpfthings
Sat Sept 13 2008, 06:21AM Print
lpfthings Registered Member #1361 Joined: Thu Feb 28 2008, 10:57AM
I accidently hit the primary. I am thinking its repairable, since I dont think it will mind if a couple of windings are missing.
What do you think I should do?
I'll attach a pic in a little while
Thanks
EDIT: SH!T, looks like ive cut through a few of the windings dead
It would be ALOT easier for me (I think) to rewind the primary than it would to redisect the secondary. Are there any formula's to calculate how many windings i'd need to run this thing from 240V again?
Thanks
EDITEDIT: Is it possible for me to simply lift the windings I cut through, up, and just resolder them? Will it affect how the transformer works if I did that?
Sat Sept 13 2008, 07:19AM
Problem 1: I can't see any picture frown Edit: Sorry, I thought you wanted to attach it and failed
Problem 2: The MOT primary is machine wound extremely tightly so there is the minimum possible space between the turns.
It is impossible to wind the primary as tightly like the original with hand; you'll probably never fit more than 2/3 of the turns of the original winding with the same wire thickness.
As to removing turns, that's not doable as the original winding already has the absolute minimum possible turns, any less and it will draw huge currents without load (well, it already does even with the original winding tongue ).
lpfthings
Sat Sept 13 2008, 07:34AM
Hi, I can seem to find my camera. But basically, about 5 peices of wire have been cut from each other. I have no idea where they all went, since they have been twisted. I guess i'll just have to try figure out where they each went frown
Sat Sept 13 2008, 03:48PM
Sounds like you are better off spending the time looking for a new MOT :(
I would gladly give you one from my collection, but its not really worth sending a MOT around the world :)
FastMHz
Sat Sept 13 2008, 05:45PM
FastMHz Registered Member #179 Joined: Thu Feb 16 2006, 02:08AM
Location: Hagerstown, Maryland - Close to Prime Outlets
Yeah, time for a new MOT....they're cheap on eBay, junk yards, and free on bulk appliance pickup day cheesey
