  • Guests: 32
  • Members: 1
40n60's
Desmogod
Fri Mar 03 2006, 12:30AM Print
Having had my FET's stolen, I'm now going to use my 40n60 IGBT's
What is the best way to get the 20+V gate drive needed from UCC's?
1.5:1 GDT?
Fri Mar 03 2006, 01:24AM
Use the gate drivers in push-pull configuration (provides +15/-15 to gate transformer) and a 1:2:2 gate transformer design. This is the typical configuration used in most DRSSTCs.
Desmogod
Fri Mar 03 2006, 01:35AM
so one inverting, one non inverting, and a 1:2:2?
Lovely.
Is it ok to wind, say, 10 turns of single wire, then 20 turns of bifilar(for a half bridge)?
Fri Mar 03 2006, 02:18AM
Desmo wrote ...
Lovely.
The best arrangement should either be:
1. Trifillar winding (3 turns intertwined)
2. Layering with the primary winding the middle layer
However, layering does increase leakage inductance. Best bet is trifillar wound. Start with 3 equal strands of wire. Wind 20 turns, then you can cut the primary wire in half paralleling it. This is the easiest way to do it.
Dr. SSTC
Fri Jul 04 2008, 04:17AM
Dr. SSTC Registered Member #1407 Joined: Fri Mar 21 2008, 07:09AM
how did you get your fets stolen
Fri Jul 04 2008, 09:59AM
My DRSSTC worked fine with a 1:1:1 GDT, I never found the need to go to 1:2:2.
Fri Jul 04 2008, 06:42PM
Yeah, but you baby those things and probably dont even exceed their peak current rating.
The issue here is desaturation of the Vce junction from excessive currents. The datasheet provides Vce vs Vge vs Ic graphs, extrapolate from them to figure out what gate drive voltage you need. I dont think the 40N60s would like 600 to 1000A with only 15Vge, and so you must overdrive the gate to keep them from desaturating.
GeordieBoy
Fri Jul 04 2008, 09:43PM
That may be true, but Steve's coil produces some very impressive sparks for it's size. I guess that keeping within device maximum ratings is just something that is ingrained into us engineer types. Out of interest Steve C, how many sets of those IGBTs have you been been through so far...? ;)
Marko
Fri Jul 04 2008, 09:57PM
If I can speak for his name - I'm pretty sure he never replaced his IGBT's, and actually I think he mentioned it somewhere here not-so-long ago.
Staying within ratings is surely a good way to keep your IGBT's - but if I wanted to acheive spark lengths like Steve W. does on his DRSSTC1 on same coil size, it would be rather troubling to find the IGBT's that I wouldn't overrate.
Those would most likely need to be bricks, but their problem would be that they would be rather slow for typical frequencies around 100kHz. So I don't know how well would they perform.
Steve Conner once said that small and medium DRSSTC's are pushing what any IGBT can do - which is probably right..
Marko
Sat Jul 05 2008, 12:36PM
I've never blown one. I'm still running the four that I started with.
Steve Ward is right, I effectively "babied" them by putting them into a coil about half the size that most people would build with a fullbridge of 40N60s. That way, I could generate sparks that looked impressively big compared to the coil (my record is 4.4x the secondary coil length) without even exceeding the manufacturer's 400A peak rating. I just set the limiter to 400A and forgot about it.
Like Richie mentions, I just don't see the point in overrating. When you do it, you're basically saying that you understand IGBT reliability and failure mechanisms better than the guys who make them, which of course you don't.
Yes, I did say that small and medium coils are right on the edge of what any IGBT can do. If you make the device bigger so that conduction losses don't kill it, then the increased switching losses kill it instead. If it weren't for Fairchild's latest generation of fast IGBTs, we couldn't have made tabletop sized coils at all.
With big coils the frequency is lower and the switching losses less of a problem.
