  • Guests: 37
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
Battery Charging and Management
EDY19
Sat Sept 13 2008, 03:42AM Print
Hello! It seems that I haven't posted forever! But I'm back for a quickie smile
I'm working on a project that will be battery operated from 2 NiMH batteries - the predicted maximum current to be delivered by the batteries is <150mA. The device will be rechargable via a Wall Wart, and the device will have a DC power input jack that is connected to the wall wart transformer. The wall wart should be able to be charge the 2 NiMH batteries while the device is off, but the device shall run from the wall wart when it is plugged in and "On". Anyone know of a battery management controller IC that will do this? I've been searching through datasheets, but any help is appreciated if you know of one right off the bat!
Electroholic
Sat Sept 13 2008, 06:31AM
i think ti makes power mux
FastMHz
Sat Sept 13 2008, 05:42PM
FastMHz Registered Member #179 Joined: Thu Feb 16 2006, 02:08AM
Location: Hagerstown, Maryland - Close to Prime Outlets
Those little DC power jacks usually have some kind of built in switch allowing incoming external power to be used when connected, and run off the batteries when disconnected. Would that work?
Ken M.
Sat Sept 13 2008, 07:44PM
Check out maxim, they make chips like that, I just dont remember the pasrt #'s.
Sat Sept 13 2008, 09:22PM
MC33340* and MC33342* are NiCd/NiMH battery fast charge controllers, and MC33341* are battery charger control regulator circuits from ON Semiconductors.
Maxim offer their MAX712 and MAX713 NiCd/NiMH Battery Fast-Charge Controllers as suggested by Ken M. above.
Ken M.
Sun Sept 14 2008, 12:20AM
I only knew about the maxim ones, since i sampled some chips some time ago and signed up for their engineering notes newsletter, I get one maybe...every month or other month with info on new products and such and they show xample circuits for some of the chips, I glance threw them since most of the semiconductors are smt ics and I'm not too big on surface mount stuff, plus how often am I gonna design a cellphone or laptop?
Sun Sept 14 2008, 09:52PM
Well I don't know about you guys, but I just finished designing a product with a Li-Ion battery system managed by a MAX1737 :P
You can't avoid SMT nowadays, there are so many good chips that come in SMT only.
aonomus
Mon Sept 15 2008, 02:35PM
Almost all the good stuff from Maxim are SMT sadly. What ever happened to the breadboard? :(
Mon Sept 15 2008, 02:53PM
It got dragged kicking and screaming into the 21st century: Link2
aonomus
Mon Sept 15 2008, 05:15PM
Hey, I ordered from futurlec and I still haven't received my shipment!
