  • Guests: 42
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
Tube data
Myke
Sun Sept 07 2008, 06:27PM Print
Hi, went to an electronics swapmeet today and I can't find the data for two tubes.
First one has a label of 589752-1. Yeah, it has a broken base but it should be fine (becuase the base was broken, I got it for a couple bucks.)
2836299269 2014155657 B
The second is the tube on the left with the label of CK-1081. I'd assume that it has similar function to the tube on the right labeled CK-1013 because the tube construction looks similar.
2836299285 2b6bcb0220 B
Sun Sept 07 2008, 07:14PM
The large Eimac seems to be a triode, but I cant find anything on it.
Found nothing on ck-1081 either.
CK-1013, it got a similar tube called 5517 its a cold cathode halfwave rectifier.
Sun Sept 07 2008, 07:53PM
CK1013 is equivalent to Raytheon CK5517. It is a cold cathode, gas filled half wave rectifier, PIV max 2800V, peak cathode current 100mA.
Pins 1,2, 6 & 7 are all the Cathode.
Pins 3 & 5 are No Connection.
Pin 4 is the Starter Electrode.
Top Cap is the Anode.
Electroholic
Sun Sept 07 2008, 09:04PM
Found 589752-1 on this page
4PR6S0C returns nothing, but heres 4PR60C from eimac.
Looks like it was used in radar for pulse modulation.
Is the base seal totally broken? Still a nice paper weight tho.
Myke
Sun Sept 07 2008, 09:28PM
The base seal looks like it's fine. Just the ceramic is broken which isn't really a problem. Wonder what I could do with it besides build another small VTTC...
So no one can find ratings for the CK-1081? Thanks for all the info so far though smile
Wed Sept 10 2008, 02:33PM
With maximum ratings of 20kV/18A on the plate for pulse modulation.... but no maximum frequency is given, which makes me think it could be pretty low.
I dont know how radar pulseswork other than its at high frequnecies, so I might be mistaken.
