  • Guests: 48
help, voltage multiplier newbie
Mamon33
Thu Sept 04 2008, 07:07PM Print
Mamon33 Registered Member #1678 Joined: Thu Sept 04 2008, 05:59PM
i just built a half-wave Crockroft Walton voltage multiplier, of 2 stages ( 2 x 1N4007 Vf=1.1v diodes , and 2 x 10nf 1kV caps each stage), the input is 120v ac at 60hz. I made a simulation of the circuit and the output is 675 volts. when i measure the output with a tester, it reads 240 volts. I dont know whats wrong:
why the simulation says one value and the tester another?
to calculate the load current (for Vdrop), do i have to put a resistor at the output node?
i made a lot of research but still i get some confusion.
what is the Vripple? does it affects the output voltage?
Please , i need some hints.
Thu Sept 04 2008, 07:25PM
10n at 60Hz is reaaally low... the meter is probably loading it down so much that the voltage drops...
Shaun
Fri Sept 05 2008, 12:04AM
Try putting a big capacitor from +HV to ground, and measuring the voltage it charges to. Dr. kV is right, you will barely get any power out of this setup as is.
rp181
Fri Sept 05 2008, 12:31AM
as they said, if its too low capacitance, the multimeter will drain it (i tried with a boost and a ceraminc cap =p).
Mamon33
Fri Sept 05 2008, 07:51AM
does the circuit need to be grounded?
i just tweakd the multimeter in the sim so the voltage resistance is 10M ohm, like my real tester. The result after running the simulation was around 308v, still not close to the 240v on my multimeter...
as for the reactance, does it has something to do with the load resistance for the time constant "tao" ?
im concerned that i did this thing backwards, with very few calculations on first place.
i just measure each cap , circuit conected to power source, and 3 of them measure around 150v . the close one to output measures 256v.
ill try to find caps with bigger capacitance.
thnx
1220600242 1678 FT53478 Sim4n
Lakeowner
Fri Sept 05 2008, 03:16PM
Lakeowner Registered Member #1370 Joined: Mon Mar 03 2008, 09:01AM
The circuit doesn't need to be grounded.
Firefox
Fri Sept 05 2008, 05:33PM
Firefox Registered Member #1389 Joined: Thu Mar 13 2008, 12:50AM
Motor run caps at 4-10uF would probably work well for this application. You will likely need to balast the input on that though, to keep from blowing out the diodes.
Mamon33
Sun Sept 07 2008, 07:47AM
how can i find the load current, do i need a resistor? if so, where do i put the resistor on the circuit?
i made some analisis in AC with a friend for positive and negative waves, where on each wave some diodes are open and others short. that is to find C equiv for each wave, bcuz he sugested me to do so to apply it in "tao".
for "tao"=RL*C, that it is the time of discharge, and T = 1/freq the time of each sin wave from 0 to 2*pi, there must be a RL*C>>T... or RL*Ceq>>T , where Ceq is the bigger value in boths half waves.
what i want to know is if these 10nf caps are usefull in this thing, cuz they discharge too fast i think. so i want to find a time constant large enough so they can not discharge too soon, if that can somehow fix it.
or find the optimum value of the caps if posible for this job.
thnx
Electroholic
Sun Sept 07 2008, 09:52AM
optimal capacitance value depends on the kind of output voltage and current you want.
VOUT = 2n*Vpk - VDROP
VDROP = [Iload/(6fC)] * (4n3 + 3n2 - n)
n is the number of stage.
For more power, i would use some 200V lytics, somewhere around 10 to 100uf. The caps don't see AC anyways, using AC caps in this circuit would be a waste.
Mamon33
Sun Sept 07 2008, 05:55PM
i know what ur talkin about Electroholic
ok, so how much load current would be necesary ( in milli, micro Amp) ?
and there is no need for a load resistor in this kind of circuit?
