  • Guests: 44
Stud-mount SCR - Mount on +ve buss bar or -ve buss bar?
aonomus
Tue Sept 02 2008, 07:17AM Print
For my coil gun I have a stud-mount SCR with current flowing from stud to lead and I'm wondering whether I should mount the short lead into the -ve buss bar and terminate the coil onto the stud, or the other way around and mount the stud to the buss bar with the lead going to the coil. Its a matter of semantics but I'm wondering if there would be any difference with the coil at 400V potential or 0V potential
My cap bank (tiny, wouldn't even qualify for a bank):
IMG 0373
Right now its shown with the lead on the -ve buss bar, although I can easily drill a hole to fit the full stud and mount it, I'd rather leave the bar intact until I decide.
Tue Sept 02 2008, 01:00PM
For ease of triggering, you'll want the cathode of the SCR connected to whatever part of your circuit you're considering as "ground". The negative bus bar would be a good place for ground, so I'm voting for negative.
rp181
Wed Sept 03 2008, 01:46AM
cathode to bus bar, its much easier to aattack a wire to a stud then a hole.
aonomus
Wed Sept 03 2008, 09:56AM
IMG 0391
I drilled a hole big enough for the stud to mount to on a short piece of flattened copper pipe with 2 extra holes for mounting/connections. Also note the result: Link2
I suppose I need to find a more secure way to mount the barrel/coil assembly :D I'll consider it a success!
guitardude012
Wed Sept 03 2008, 03:33PM
guitardude012 Registered Member #968 Joined: Fri Aug 24 2007, 04:54PM
aonomus wrote ...
I like drilling a hole through a small block or blocks of wood to secure the barrel. Or HDPE if you want to get fancy ;)
