  • Guests: 45
Finishing up - Boost question :)
Killa-X
Mon Sept 01 2008, 08:13AM Print
Finishing up my "ask the forums!" streak. All is working fine. now, seeing as my cam charger fails at life, i need a new design. I heard about Boost converters going for coilguns...
Whats the best schematic going around the web to make one?
Input voltage: I dk as long as its not 50K batterys
Output voltage: 350 Volts
Id also need a lil tip on changing it to fit my required voltage divides..
Sry for all the questions / helps but the coilgun is a new thing to me. I know more the microcontroller programming section. LCD 20*4, graphical, sounds, keyboards, mechanics, etc..
youngcoilgunner
Tue Sept 02 2008, 04:33AM
youngcoilgunner Registered Member #1633 Joined: Tue Aug 12 2008, 04:21AM
ok, so you first need an oscillator stage, you could use a 555 timer for this. then you need a Fet driver, something like the Texas instruments TL2812 should work. then you'll need either a high voltage Mosfet or IGBT, something like 1200v and 13 amps should do the trick. and you'll need two fast action diodes, rated for about the same parameters as your FET.
aonomus
Tue Sept 02 2008, 07:01AM
I just built this one myself and it works great
Just keep in mind that it does need heatsinking, and that the diode tab is at a different potential than the MOSFET tab (and failing to isolate the diode also means that the diode heatsink is at 400V!).
guitardude012
Tue Sept 02 2008, 02:26PM
guitardude012 Registered Member #968 Joined: Fri Aug 24 2007, 04:54PM
How would you isolate the diode?
aonomus
Tue Sept 02 2008, 03:20PM
Silicone pad + nylon washer
Killa-X
Tue Sept 02 2008, 05:09PM
aonomus wrote ...
Maybe you can help me then. The guy in my aim isn't on much...
Would it kill to post a list of parts that i can get of digikey or something? I've never made a boost converter so, My diodes are rated 1000V 10amps but not fast action...
aonomus
Wed Sept 03 2008, 01:47AM
Well the major parts to the boost converter that I built are:
MOSFET: IRFP450
Inductor: 125uH choke (Digikey PN M8272-ND)
Diode: RURP1560
The rest of the parts are the 555, the LM311, ic sockets, some ceramic caps, etc.
Killa-X
Wed Sept 03 2008, 02:01AM
aonomus wrote ...
MOSFET: IRFP450
Diode: RURP1560
Thanks, I can get the 555, maybe the heatsinks, and the socket at radioshack for sure. But should i follow this schematic?
rp181
Wed Sept 03 2008, 03:15AM
its actually better and eaiser to understand the theory behind a boost converter and make your own.
Killa-X
Wed Sept 03 2008, 07:10PM
rp181 wrote ...
Mmmk, All the parts i was told to get are just special higher power parts.. basic diodes but high power..I can prob. figure most of it, but i was told to get voltage divides, and stuff.. So its finding out what to use to GET a set power, and not climb to infinity. xD
Some places like wiki just show simple circuits. diode. powere source. switch. inductor.
