  • Guests: 37
williamn (48)
ReddyK (57)
Birdman (31)
12/14 M.A.D. (32)
12/15 marko666 (58)
12/16 Will T (16)
Magnet Wire Suppliers
Firefox
Fri Aug 29 2008, 03:53PM Print
Firefox Registered Member #1389 Joined: Thu Mar 13 2008, 12:50AM
I am looking around to find a good place to buy magnet wire, and I stumbled across Magnet4less.com. Has anyone ever had experience with this company, and if so, are they any good? Parawire.com also seems to have reasonable prices. Their prices are about half that of bulkwire.com, which was suggested by FastMHz in a thread about magnet wire a few months back. I am kind of cheap, so I'm looking for the best price on the wire, but I'm always wary about trying new online dealers.
Fri Aug 29 2008, 04:14PM
Sometimes, searching for "enamelled copper wire" will produce better results than a search for "magnet wire."
Fri Aug 29 2008, 04:50PM
Compared to danish prices I have found cheap 2000ft spools on ebay.
Fraggle
Fri Aug 29 2008, 10:25PM
Fraggle Registered Member #1526 Joined: Mon Jun 09 2008, 12:56AM
Definitely - `magnet wire` is just a slang term really.
Sat Aug 30 2008, 01:36AM
Well the magnet wire from parawire is heavy build insulated and i am using it and it is great. I got the wire i needed for less than anywhere else and there was not one place in the wire that was bent had stripped coating and no tangling. I was very satisfied and that is where i will buy all of the wire i will ever need ;).
Coronafix
Sat Aug 30 2008, 04:11AM
Just ring up a motor rewinding place, they will by far be the cheapest.
They sell by weight, so you need to work out how much you need.
Firefox
Sat Aug 30 2008, 04:46AM
Oh, I see. So the motor winding place buys probably 200 lb spools and then respools the weight you ask for, allowing you to get the bulk discound then? I may just do that if I can find one in the area.
Sat Aug 30 2008, 07:56AM
Firefox wrote ...
I tried that in Denmark, but unfiortunately they want a high price for a new spool and the worktime to respool it, so it ends up being more expensive :(
Seoul_lasers
Sat Aug 30 2008, 09:20AM
Seoul_lasers Registered Member #1630 Joined: Sat Aug 09 2008, 11:36AM
MadsKaizer wrote ...
Firefox wrote ...
You are making it sound like they respool by hand. It is done by a large machine and takes all of 2 minutes.
THERE SHOULD NOT BE a big difference in cost!
50lbs does 1 8"dia coil (1800x) 1x 6.5" coil 1500x and 1x3.5" (1650x) ... .that was 50lbs of #26ga !!! How many coils are you doing with 200lbs????
Sat Aug 30 2008, 01:41PM
I cant remember the exact details of the request, but it was something like 60$ for the wire, 40$ for respooling and 10$ for the new spool, its not a joke, its hard to find cheap components in denmark :(
