  • Guests: 40
Geiger tube supply?
Thu Mar 23 2006, 06:49PM Print
Hi all.
I'm trying to build a miniature Geiger counter into one of those "step" counters as a dosimeter.
The main problem is that I can't find a circuit that generates 400+V efficiently (i.e. drawing less than 1mA) from 1.5V.
Has anyone tried this? My best guess would be some sort of EL based driver (the HV8xx series) as they seem very efficient, but they are tricky to get hold of.
Regards,
-A
RickR
Thu Mar 23 2006, 08:27PM
RickR Registered Member #93 Joined: Thu Feb 09 2006, 04:11PM
Is there any reason it HAS to be 1.5 volts? Here are some schematics for 3 and 9 volts. It would seem you could stack button cells to get the needed voltage if you're not planning on running it for extended periods.
http://www.techlib.com/science/geiger.html
Rick
Self Defenestrate
Thu Mar 23 2006, 10:39PM
Self Defenestrate Registered Member #87 Joined: Thu Feb 09 2006, 01:36PM
I know its not the best, but perhaps a camera flash transformer is in order?
Omicron
Sun Apr 02 2006, 04:12AM
Omicron Registered Member #131 Joined: Fri Feb 10 2006, 09:25PM
There are lots of sites on the Internet that have these circuits check google.
