  • Guests: 50
suggestions for simple low power, 1 volt converter
kell
Thu Mar 23 2006, 02:29PM Print
kell Registered Member #142 Joined: Sat Feb 11 2006, 01:19PM
Looking to build a one volt, one watt dc to dc converter, input 5 to 18 volts.
5 or 10% regulation good enough.
Simplicity is the order of the day.
Topologies, links, suggestions welcome.
It will drive the base of a power transistor used in a switching cascode configuration.
Wolfram
Thu Mar 23 2006, 03:33PM
Check out the PTH08080W from Texas Instruments. Looks like exactly what you need, and not too expensive either. And they can be sampled.
kell
Thu Mar 23 2006, 11:40PM
I did request a sample. Unfortunately, if I ever want to use this chip again, the minimum quantity to buy is 90, available only from TI, not one of their listed vendors stocks it.
Simon
Fri Mar 24 2006, 01:22AM
What about a low duty-cycle chopper?
How important is efficiency? I mean, there are lots of ways to lose those volts...
Bjørn
Fri Mar 24 2006, 03:21AM
I have used this one for lamps where a linear regulator could not cope with the power.
http://sciencezero.org/electronics/simpleswitcher.htm
Fri Mar 24 2006, 02:37PM
what kind of load current are you talking about?
Dr. Shark
Fri Mar 24 2006, 04:52PM
He is talking about 1V 1W, so I suppose it is 1A.
A simple buck converter driven from a 555 timer could do this, but I don't know if the regulation would be good enough.
kell
Fri Mar 24 2006, 05:28PM
Bjørn Bæverfjord wrote ...
Interesting. I assume input is on the left and output on the right, which means that circuit is open loop. It might work for a constant load like a lamp, which is what they said they used it for. But what happens with a dynamic load?
To make a simple circuit like that but with load regulation, maybe youse gotta use a real feedback loop from the output, with hysteresis so that it switches instead of running linear. Require a few extra resistors. Maybe I'll see if I can work up something like that, using an op-amp and mosfet or darlington.
Edit: D'oh, and an inductor.
Fri Mar 24 2006, 05:32PM
I'm guessing you want an isolated DC-DC converter to give a floating supply? I developed a simple DC-DC converter based on the "ZVS" circuit to power the outboard floating IGBT drivers on my next coil. It's unregulated but seems to work well enough. There was a thread about it on the old board: Link2
If you don't need any isolation, a plain buck converter will do fine and you can easily make one of those with a TL494 or whatever.
Bjørn
Fri Mar 24 2006, 06:26PM
There is nothing linear about the circuit, the transistor gets a squarewave in the kHz to MHz range depending on what components are used.
