  • Guests: 54
Capacitor Dielectrics and Applications
Firefox
Tue Aug 26 2008, 03:18PM Print
Firefox Registered Member #1389 Joined: Thu Mar 13 2008, 12:50AM
I was searching around on Ebay for good HV stuff, and came across a guy who sells HV polystyrene and polypropylene capacitors. The deal of $50 for 12 30kVDC 2nF caps seems pretty good, but I don't know how good polystyrene is for CWs and Marx Generators (which is where I would use them). The only dielectric I know is 'good' is PET, boPET, or PETP.
So, would this be a good investment, or would it be better to use seriesed CDE 942s or homemade overhead caps instead?
Tue Aug 26 2008, 08:15PM
I too looked at the huge polystyrene capacitors.
Look at the terminations .. not a pulse cap I think.
Note that the stated applications do not include any pulse duty.
Polystyrene has a very low melting point
and traditionally the 'suflex' brand were prone to contamination via the wound ends.
Polystyrene is a good low loss dielectric at rf (not the best) and is easily metalized for manufacturing
but one of it's key benefits is a negative temperature coefficient of capacitance which almost exactly cancels the positive temperature coefficient of inductance of an air-wound coil, great for rf tuned-circuits but not particularly useful for a TC.
So overall I think they're beautiful capacitors but not ideal for TC work.
(I think these caps may have to be potted or under oil to achieve the voltage rating)
P.S. I have had for years 11x 18nF 2.5kV Suflex brand polystyrene caps for general experimenting
and I've not once tried them in TC service ...... too nice to kill!
P.P.S. In order of dielectric loss at TC frequencies
Vacuum, air, ptfe, etfe, pp, pe, ps............. MKT then unsuitables such as paper/oil, Y- or Z- ceramics etc.
Firefox
Tue Aug 26 2008, 08:50PM
Thanks Sulaiman. I hadn't intended to use them in TC duty, I was planning to use them in Marx or CW multipliers. Since you said they probably are not good in pulse duty, I guess I have to take Marx generators off the list, which leaves the CW multiplier. Knowing that they are less lossy than PET or PP is a bonus too!
Here are the Caps. What do you think, good for CW service with 15-20kV input?
Wed Aug 27 2008, 08:59PM
Look a few inches down in the listing,
it clearly states " should be used in insulating oil without aromatic series or be used in silicone rubber."
If that's ok for your project then good.
My list was in order of dielectric "goodness", best at the left .. sorry.
These capacitors look so well made (completely transparent at the ends) they're worth buying as a 'visible' capacitor.
There must be a new manufacturer of polystyrene film, so these capacitors may be better than my old experiences.
Firefox
Wed Aug 27 2008, 09:13PM
Putting it under oil shouldn't be a problem. I don't know much about aromatic series' (never was particularlly interested in O-Chem), but do mineral or vegitable (probably sunflower) oils have them? Those would probably be the easiest things to get my hands on for this.
Seoul_lasers
Thu Aug 28 2008, 02:00AM
Seoul_lasers Registered Member #1630 Joined: Sat Aug 09 2008, 11:36AM
PS dielectric isn't very good. I would be tempted to use Polyethylene for marx generators as it has much higher current capability.
940C 942C from CDE are perfect for building marx or Walter Crofton impulse generators or those sorts of things.
Firefox
Thu Aug 28 2008, 02:31AM
Thanks Seoul. I am planning a large-ish 60-100kV CW multiplier using the caps I ultimately decide to use. I was asking about these caps, because even half rated, their voltage stand-off (under oil anyway) is much cheaper per kV than CDE caps, and I wasnt terribly concerned about the capacitance. I've used 22nF film caps in a small multiplier at high frequency and got a very reasonable result. Heck, I've used 56 pF caps, and they still worked well, though I believe the driving frequency was around 40 or 50kHz.
Also, Seoul, unless you have very high current diodes that can handle the abuse (which I think you would be hard pressed to find), a Cockcroft Walton multiplier is typically used as a high ripple, low current high voltage source, not an impulse generator. Typical current is generally less than a few milliamps, though Steve's seemed to have more than that (probably around 20mA), as the arc was a yellow power arc instead of a purple low current arc.
aonomus
Thu Aug 28 2008, 03:03AM
From what I can figure, 940c are available from Digikey, but 942c's are the most sought after with the highest dV/dT are not available from digikey (I think the last time I checked they were from Mouser). 942c's are available on ebay however I'm not sure how reputable some people are.
Seoul_lasers
Thu Aug 28 2008, 04:34AM
Firefox wrote ...
Diodes aren't hard to find here in Seoul ( have have seen loads of them), I would suggest MOT oven diodes. They will probably work fine. They are rated for 2-3Kv 450mA ...
I have never built a large one before but if my calcs are correct this should be perfectly fine.
They are exactly cheap.
Firefox
Thu Aug 28 2008, 05:23AM
Diodes aren't a problem, in fact, I just ordered 40 8kV 10mA diodes for this CW. I'm just saying that you need fairly good ones to use a CW as an impulse generator. Putting a large limitting resistor (100x 10k resistors in series, for example) on the output solves that problem entirely by limiting the output current to those levels.
