  • Guests: 44
OiD (38)
jolty (50)
Baran (29)
10/16 Sanchez (36)
10/16 Knarvel (13)
New Heatsinks
MRacerxdl
Mon Aug 25 2008, 01:35PM Print
Hi,
today I have finished to get this heatsink like new by polishing it (a bit) and cleaning. I make the hole for the IRFP250 too.
I was thinking about it, can I push 1000W or so with Halfbridge of IRFP250 with those heatsinks? (Each mosfet on each heatsink)
Photos:
Thanks!
Mon Aug 25 2008, 07:02PM
Mestre Racerxdl wrote ...
1) 1000W for voltage power supply (high power factor)? Yes.
2) 1000W for inductively limited current supply (arcs, capacitor charging)? Maybe, but I think they will be getting very hot. Remember that pushing 1000W with inductively current limited supply means 4000VA with short-circuited output.
3) Maybe you meant for "ZVS" driver? If so, I think that should be without bigger problems.
P.S. nice sinks smile
MRacerxdl
Mon Aug 25 2008, 07:24PM
Hmm, I was not mean the ZVS driver, I am building a SSTC with that heatsinks and IRFP250N (200V 30A). I am running here now something like 450W without get any heat on the fets or heatsink. Three Turns on the primary coil, and perfect tunned.
But I think to use it on a DRSSTC with some IGBT's that I have sampled from ST Microelectronics, also I want to test a Induction Heater.
Thats why I asking if I can push 1000W with that :P
P.S. nice sinks
Thanks! I just found it in some old computer stuff, and its two exact same. I took me two hours to get it usable :P
Mon Aug 25 2008, 08:11PM
I think for SSTC they should be fine to 1000W, as with higher powers and good coupling the transistors are more-or-less soft switching.
Coronafix
Mon Aug 25 2008, 10:15PM
You could join them toe to toe and put a fan in at the end, this should increase
your chances of pushing it to high power levels.
MRacerxdl
Tue Aug 26 2008, 12:23AM
I am using now one fan (8x8, normal ones) to get it cool. I running at 450W~ SSTC and it didnt get any heat. I will try to reduce turns and get higher coupling.
I was thinking about it using for some mini-bricks that I plan to buy. If you see in the upper area, there is a square area that can have a mini-brick. That is a good heatsink for each one? (Like 40N60 ones)
