  • Guests: 45
OiD (38)
jolty (50)
Baran (29)
10/16 Sanchez (36)
10/16 Knarvel (13)
not-quite bench power supply
ragnar
Sun Aug 10 2008, 05:48AM Print
For a distraction, here's my LM317 in a box with a twelve-way rotary switch to select 1.5V, 3.0V, 3.3V, 4.5V, 5V, 6V, 8V, 9V, 12V, 15V, 20V or 24V. A red 3.5 digit LED displays the output voltage.
1218347381 63 FT1630 Lm317box1
1218347381 63 FT1630 Lm317box2
1218347381 63 FT1630 Lm317box3
Avi
Sun Aug 10 2008, 06:23AM
remember to disconnect the load before changing the knob :)
ragnar
Sun Aug 10 2008, 06:39AM
You're right -- the switch is break-before-make; perhaps I should put capacitors across ADJ so that it slews slowly.
Avi
Sun Aug 10 2008, 07:20AM
yep lol, theres an article in this months silicon chip magazine about that, but it refers to the jaycar regulator module.
Dr. SSTC
Sun Aug 10 2008, 07:33AM
Dr. SSTC Registered Member #1407 Joined: Fri Mar 21 2008, 07:09AM
Avi wrote ...
i never knew that jaycar had stores in melbourne lol i have a jaycar fairly close to me only 50 meters or so
Avi
Sun Aug 10 2008, 07:52AM
here is the regulator it refers to Link2 (which is actually discussed in last months magazine)
but there was a comment about the switching of the voltages in this months.
Let me know how well your capacitor idea works and what value you used.
aonomus
Sun Aug 10 2008, 08:00AM
Is that display a straight voltmeter module, or a HD44780 display?
Sun Aug 10 2008, 10:27AM
Very nice, Matt.
flannelhead
Sun Aug 10 2008, 10:50AM
Uzzors wrote ...
Very nice, Matt.
Totally agree! smile I'd have ended up with a bare PC board without any kind of casing...
ragnar
Sun Aug 10 2008, 02:25PM
wrote ...
here is the regulator it refers to (which is actually discussed in last months magazine)
Hey, that's their old LM317 kit with a pass transistor slapped on.
I left space in the box for some 2N2955 pass transistors, but I'm not expecting so much current.
wrote ...
Yep, even at 2.5Hz update, I can see from the display that the voltage jumps when I move the rotary switch.
wrote ...
I'll put something between output > ADJ, ground > ADJ -- I guess they can be pretty small, because the rotary switch goes *open circuit* after all...
wrote ...
Jaycar QP5580.
wrote ...
Totally agree! I'd have ended up with a bare PC board without any kind of casing...
Well, for a while I did use a small PCB with an LM7815 and an LM7805 on it, but the heatsinks were too small (pcb-mounted), alligator clips always seem to make their way into it, and there was the risk it would go nuts around my coils, hence the new aluminium enclosure wink
