  • Guests: 21
GhostlyFigures (36)
10/06 Ivan Kalafatic (17)
10/07 Pyromaniac (34)
10/07 Wavetuner (76)
Variac questions
Myke
Sun Aug 03 2008, 10:48PM Print
Hi, I got a 15A 0-140V variac and it seems to be shorted somewhere when power is applied. I measured the inductance of the 120V side and I got 1.8H. When I connected it to the line it hummed and then tripped the breaker after a couple seconds. I took it appart and found nothing wrong with it. On the side plate it said that it was rated for 400CY. Does this mean 400Hz? Is it okay to run it on 60Hz? What do they use 400Hz for anyways? I have a smaller variac that is also rated for 400Hz but also 60Hz. If I can't run it on 60Hz what could I use it for?
Tonic
Sun Aug 03 2008, 11:27PM
What exactly was rated? Perhaps you should give a photo of plate. Was variac powered without ballast or soft-start circuit? Without that, my 2.2kVA variac would trip breaker instantly, but if it's couple seconds for you, then I'm not sure if it's a inrush current issue.. (with big toroid, a few of kVA's, it's almost certain that when you plug it to mains, a big current damps into and trips breaker/fuse).
Mon Aug 04 2008, 01:17AM
That variac is no good for 60Hz.
400Hz is typically used for aircraft as its allows the use of smaller magnetics (hence lighter power supplies etc...) in the aircraft.
For your variac, that also means the core is different that what it would be for 60hz operation.
Myke
Mon Aug 04 2008, 03:05AM
The plate says:
TYPE: 7404 SER:
INPUT:120V. 1Φ 400CY.
OUTPUT VOLTAGE: 0-140V.
MAX. OUTPUT 2.1KVA 15AMP.
Is there anything I could use it for? Maybe I could get an aircraft generator and use that to make 120V 400Hz?
Backyard Skunkworks
Mon Aug 04 2008, 03:46AM
I guess you could make an inverter that puts out 400hz and use it with that?
cbfull
Mon Aug 04 2008, 01:18PM
Aren't iron laminate transformers claimed to be okay to use up around 400Hz, or is it 4000Hz? I can't remember what the upper cutoff frequency is for a common transformer, but at first I thought that's what you were seeing, the maximum applicable frequency.
After seeing the way it's stated on the plate, I'm with Gigavolt, the core is saturating (and if it's rated for 400Hz, it's saturating rather quickly) and causing a rather large current draw from your mains.
The only way I can think that you could still use that variac on 120V @60Hz is to ballast it with a large inductor, such as another transformers primary.
teslacoolguy
Tue Aug 05 2008, 05:06AM
could the variac run on a 400hz squarewave?. I ask this because i have ran iron cored ignition coils with a squarewave up to frequencies as high as 20khz without any saturation problem.
