  • Guests: 31
Pyromaniac (34)
Wavetuner (76)
jeffomatic (75)
SparkLabs (36)
10/07 Pyromaniac (34)
10/07 Wavetuner (76)
10/07 jeffomatic (75)
****NEW TESLA COIL PROJECT****
Alexandre
Fri Aug 01 2008, 03:26PM Print
Alexandre Registered Member #1228 Joined: Tue Jan 15 2008, 01:08AM
Good day coilers...
This is my new MOT power tesla coil project...
The secondary is made by a PVC tube, with 8" diameter and 24.8" winding, of #24 wire..
This is the photos..
1217556532 1228 FT0 Pict0062
1217556532 1228 FT0 Pict0070
My uncle and me..
1217556671 1228 FT0 Pict0075
Coil completed..and a small comparation with the BIG coil...
1217556803 1228 FT0 Pict0079
I use a EPOXI glue to isolate the coil externally..
1217556958 1228 FT0 Pict0179
1217556958 1228 FT0 Pict0181
coil completely finished..
1217557011 1228 FT0 Pict0183
The base was made with plywood, and cut a two circles..
1217557177 1228 FT0 Pict0082
1217557177 1228 FT0 Pict0083
And the suports are bolts and nuts with support of four of PVC pipes..
1217557312 1228 FT0 Pict0094
1217557312 1228 FT0 Pict0095
And was also a paint job on the basis and on pipes..
1217557484 1228 FT0 Pict0105
1217557484 1228 FT0 Pict0106
1217557484 1228 FT0 Pict0108
Her is a cut made on secondary to fit it in the base..
1217557945 1228 FT0 Pict0225
1217557945 1228 FT0 Pict0226
1217557946 1228 FT0 Pict0229
The coil in your base..
1217558136 1228 FT0 Pict0230
During the week put the rest of the components
Tonic
Fri Aug 01 2008, 06:37PM
Interesting method to mount secondary coil to base, I must say.
About resin, would I be right if I say that now secondary coil has "white areas" caused by resin? :) I've used resin and it turned out to be destroying beauty of secondary, exactly because of those "white areas". Now I'm just going to buy a dielectrical spray. It will surely do a much more neater work in next coils.
Alexandre
Fri Aug 01 2008, 06:43PM
The "white areas" in the coil is when the resin was still drying, dry after it is fully transparent :D
Alexandre
Fri Aug 01 2008, 06:44PM
Hi Coiler..
today iam build a MOT filter..
here is the photos...
Alexandre
Fri Aug 01 2008, 06:59PM
Safety-Spark gap
1217616562 1228 FT51236 Pict0206
1217616562 1228 FT51236 Pict0205
1217616562 1228 FT51236 Pict0204
1217616562 1228 FT51236 Pict0207
Air-Chokes, made by a #24 magnet wire in a tube of 2"..
1217616688 1228 FT51236 Pict0202
1217616688 1228 FT51236 Pict0203
basis of plywood to support ...
1217616834 1228 FT51236 Pict0211
1217616834 1228 FT51236 Pict0217
All set..
1217616922 1228 FT51236 Pict0218
1217616922 1228 FT51236 Pict0223
The single component missing are the connections with electrical wires to connect the components that will make them soon ...
Cheers
Alexandre
Sun Aug 10 2008, 03:49AM
Hi Coilers
Today i am build a primary of my tesla coil
The suports its made on acrilic 30º angle
Its a 12 turns cooper tubing of 1/4 inch
17mm space center to center of tube
pictures..
1218339902 1228 FT51236 Pict76
1218339903 1228 FT51236 Pict77
1218339903 1228 FT51236 Pict78
1218339903 1228 FT51236 Pict0232
1218340049 1228 FT51236 Pict0233
1218340049 1228 FT51236 Pict0249
1218340049 1228 FT51236 Pict0252
1218340049 1228 FT51236 Pict0255
1218340049 1228 FT51236 Pict0257
Dr. SSTC
Sun Aug 10 2008, 04:36AM
Dr. SSTC Registered Member #1407 Joined: Fri Mar 21 2008, 07:09AM
vey well made i must say
cant wait for first light
Sun Aug 10 2008, 10:44AM
Looking good there, Alexandre.
Alexandre
Sun Aug 10 2008, 02:05PM
THANKSS
Now I will mount the Mot Power suplly
soon put the photos ...
Seoul_lasers
Wed Aug 20 2008, 04:06PM
Seoul_lasers Registered Member #1630 Joined: Sat Aug 09 2008, 11:36AM
I would seriously be making that a flat primary system!
