  • Guests: 26
Pyromaniac (34)
Wavetuner (76)
jeffomatic (75)
SparkLabs (36)
10/07 Pyromaniac (34)
10/07 Wavetuner (76)
10/07 jeffomatic (75)
Simple portable solar power system
WaveRider
Sun Aug 02 2009, 01:01PM Print
It has been a while since I have had a little time to indulge in a bit of projectitis.. We have been having a fairly sunny summer in Belgium so I took the opportunity to assemble a 220W peak photovoltaic power system.
The solar panels and charge controller I procured on E-bay sometime last year. (Sorry, I do not remember the seller, but such panels are relatively easy to locate from many sellers). The batteries are 100Ah semi-traction deep-cycle lead acid batteries (the type found in electric wheelchairs and golf carts). The inverter is a 1500W, modified sine-wave static inverter that powers most household appliances without complaint.
I have assembled a simple webpage outlining some of the details and behaviour of the system at this address.
Future additions to the system will be some type of charge monitering system as well as probably adding some more PV panels to assist charging during short winter days. A small pure-sine-wave inverter may be in the cards as well....
1249218016 29 FT0 Pvpowersystem Html 3b5b0764
Sun Aug 02 2009, 05:46PM
Nice setup ... it's good to have a power system that's independant of the grid.
Edited....
I have 3 12V Lead-acid on permanent float charge 'just in case'
I keep looking for cheap solar cells but haven't got a good deal yet.
Sun Aug 02 2009, 10:08PM
Looks great smile
Why not try a constant voltage transformer with your squarusoidal inverter, instead of getting a pure sine wave inverter. I wouldn't buy a CVT new (if you can even find one) but it's the kind of thing that you might have lying around at work. They do a pretty good job of turning nasty mains waveforms into a sine wave.
aonomus
Mon Aug 03 2009, 06:36PM
Another neat addition you should think about would be adding sun-tracking. You would really only need 1 sensor/driver and just mount all the panels on gimbals, then parallel them mechanically by using braces/bars/cables, etc.
Renesis
Mon Aug 03 2009, 08:32PM
Renesis Registered Member #2028 Joined: Mon Mar 16 2009, 08:13PM
I found this document on the internet a while ago, you might find it interesting.
Edit: Darn, its too big
Edit again: Here you go: Link2
WaveRider
Thu Aug 06 2009, 10:44AM
Hi Steve: A CVT is indeed quite hard to find. I thought about making a large low-pass LC filter (a T-filter) with a cutoff of about 75 Hz or so out of some old transformer cores but the group delay may introduce more wobbles and ripples in the output waveform when things switch in or out.. I'll have to give it some thought..
aonimus: Yeah, tracking would be nice to have, but that's a project for another day!
Renesis: an even bigger project... solar thermal!
Cheers!
Fri Aug 07 2009, 06:07PM
One extra thing to consider is 'peak power tracking'
for a given light level to get the maximum POWER available the currewnt drawn needs to be controlled, e.g. 0v4 @ 30mA = 12mW, 0v35 @ 35mA= 12.25mW, 0v3 @ 40mA = 12mW.
The extra cost of the electronics is usually (I've read) less than the cost of extra cells.
aonomus
Fri Aug 07 2009, 06:23PM
Not to derail about solar electric, but solar thermal I think cost wise would be cheaper. One big 10ft satellite dish + mirroring + blackened copper pipe loop = hot water/steam...
Your array of panels could possibly supplement your AC usage, there are 'plug and play' grid tie inverters that are in the neighborhood of 200W that take 14-48VDC and output power back into a wall outlet after syncing to the grid freq.
