  • Guests: 40
williamn (48)
ReddyK (57)
Birdman (31)
12/14 M.A.D. (32)
12/15 marko666 (58)
12/16 Will T (16)
Resonant Frequency of Metal
Ryan
Fri Aug 01 2008, 01:43AM Print
Ryan Registered Member #1606 Joined: Fri Jul 25 2008, 02:40PM
Ok, I have a question for the science guru's out there. Tesla almost took down a building with a resonant frequancy he created. It was a mechanical oscillator, however here is where my question lies. Is it possible to do the same thing with electrical pulses? If somebody sent an electrical pulse at the matching Hz of a peice of steel for example, would the same "earthquake effect" be generated?
-Ryan
Turkey9
Fri Aug 01 2008, 02:01AM
I may be wrong here, but i believe that the tesla machine worked on the mechanical resonance of the building, not the electromagnetic. The only way that electricity could do the same thing is that if it was pumped into the metal at such a huge current as to create heat and make the metal expand, and then some how cool it rapidly to contract it, and then do it all again. The resonance that you hear about with tesla coils is electromagnetic resonance. Which means that the growing and colapsing magnetic/electric fields oscillate at the resonance frequency of the conductor/coil that is determined by the inductance/resistance/capacitance. That's what i think. I haven't done the research to be sure, though. It would be really interesting if you were right and i'm sure it would spark a frenzy of experimenting.
Fri Aug 01 2008, 02:24AM
like Turkey was saying, the resonance used to do his fabled building experiment is not the same thing as electrical resonance. One has to do with the steel in a building acting like a spring with a weight on the end bouncing back and forth, the other has to with alternating electric/magnetic fields.
One could, if they wanted, use electricity to cause a piece of metal move and excite the resonance in a structure, either by using a strong electromagnet or even something like a spark discharge creating a pulse of pressure, but either of these methods would probably be quite inefficient and you would have been better off just turning a motor with a off-axis mounted weight spinning around.
Ryan
Fri Aug 01 2008, 02:52AM
Okay cool thanks guys, his invention was basically a little hammer that tapped the structure at a certain rate I beleive, just wondered if it was possible with a small current being passed through a conductor (metal)
Thanks, Ryan.
Actually! Say I were to have an electromagnet on a switch.. If I were able to turn that switch on and off at whatever Hz I was after, would that setup a frequency that could be useable?
[MOD EDIT: Corrected double post)
Fri Aug 01 2008, 04:04AM
That is what I was alluding to in my previous post, simply use an electromagnet to smack against the structure. The only problem with this idea is that it would have horrible efficiency.
Turkey9
Fri Aug 01 2008, 04:40AM
Actually fixing the mechanism to the metal would be much more efficient instead of haveing it just smack into it. You can have a solenoid shift weight from side to side at the resonance and that would be closer to what tesla was doing.
Ryan
Fri Aug 01 2008, 03:19PM
OK great thanks for your help guys.
