  • Guests: 43
OiD (38)
jolty (50)
Baran (29)
10/16 Sanchez (36)
10/16 Knarvel (13)
Untimely death of a MOSFET driver
Thomas F
Wed Jul 30 2008, 08:56AM Print
Thomas F Registered Member #503 Joined: Sun Nov 19 2006, 06:37PM
Or make that 3.......
Hello,
I am using a TC4420 to drive the gate of a IRFP250N.This is pulsed at 4kHz with a on period of 8%.The connection to the gate is made through a 150E resistor for switching on the MOSFET gate, and a 6E / 1N5819 diode for switching off the same.
The MOSFET in turn drives a flyback which is used to generate a 5kV DC.The DC is from 2x103 caps , 500k resistor, 103 (x1) cap in a pi configuration.
If I draw sparks continuously I find the TC4420 fails and leaves the gate of the MOSFET permanently high.
Any clues on how to solve the issue.
Thanks
Experimentonomen
Wed Jul 30 2008, 08:59AM
Spikes, run the gate driver and the oscillator circuit off a separate supply.
Dr. SSTC
Wed Jul 30 2008, 09:01AM
Dr. SSTC Registered Member #1407 Joined: Fri Mar 21 2008, 07:09AM
so are you only going to use this circuit to drive flybacks if so than there is much easier options without using a gtc like a mazzili or a 555 with Quasi-resonant capacitor. It is possible to tune these to give you 5kv if thats all you need
Thomas F
Wed Jul 30 2008, 09:08AM
Hi ,
That can't be done I am afraid,its all powered from a single battery. Are the spikes only due to sparking ? Do you feel that the oscillator is latching up ? The oscillator is actually a micro which is doing all the other tasks without any problem.
Wed Jul 30 2008, 10:03AM
What do you use as pulse source for your gate driver?
Anyway, put 0.1uF supply decoupling caps close to all ICs, and maybe even some tantalum caps. Also check that you're not exceeding maximum ratings of the TC driver.
When the driver "fails" is it permanently damaged or not?
Thomas F
Wed Jul 30 2008, 02:36PM
Hello Dr.KVolt,
I am attaching a pdf of the relevant part of the circuit. When it fails ,it sometimes works for a few seconds and then latches High.
Any suggestions?
]5kv_v2.pdf[/file]
Wed Jul 30 2008, 06:18PM
Okay, as I said put a 0.1uF film or foil cap across the gate driver supply pins.
Are you absolutely sure it's not the input that is latching? I've never had a TC442x driver latch.
Thomas F
Wed Jul 30 2008, 07:12PM
Well I will put a 104 across the bulk cap on the supply. Actually I am assuming the input is not latching as the micro is doing the other jobs ( refreshing a muxed seven seg,reading from ADC )etc.
When I replace the TC4420 the new one works well for some time.
