  • Guests: 75
VDG Needle Question
scott712
Sun Jul 27 2008, 08:59PM Print
scott712 Registered Member #1607 Joined: Sun Jul 27 2008, 01:19AM
Why do Van de Graaf generators use needle combs to make electrical contacts between the belt and the inside of the sphere?
Also, I accidentally posted a different VDG question on the wrong forum. How might I move it to the proper forum?
How can I contact the forum moderators?
Sun Jul 27 2008, 11:14PM
scott712 wrote ...
As a charged conductor is brought to a point, the charge density on the surface of the conductor increases. In the case of the VDG combs, the charge density reaches a level where an ionic wind streams from the point, spraying the charge onto the nearest conductor having a potential difference.
This is why even very small irregularities - including dust - on the surface of a VDG accumulator sphere will cause a serious loss of the sphere's ability to accumulate and hold a charge.
Antonio
Mon Jul 28 2008, 12:31AM
It's also possible to use brushes, with a small improvement. Very light brushes, to not scratch the belt. Look at the brushes that discharge the paper in a laser printer. They work well. And work well also as combs if they don't touch the belt.
