  • Guests: 72
Marx Generator trigger circuit?
scytheavatar
Thu Jul 24 2008, 10:14AM Print
scytheavatar Registered Member #1604 Joined: Thu Jul 24 2008, 09:39AM
I am doing a project where I need to generate some very loud snapping sound, and I decided to use a Marx generator for that purpose. The problem is, I am not sure what to use for my triggering circuit. I know you can trigger the stupid and easy way with an insulating screwdriver, but I want to trigger the circuit electronically, cheaply and simply. Besides using trigger transformers is there another way to trigger the spark gaps? The visual is totally unimportant, I just need the sound. Thanks.
Also, this is a good way to generate the snapping sound, correct?
Kizmo
Thu Jul 24 2008, 10:19AM
Get high voltage pulse discharge capacitor and discharge it with triggered spark gap? How loud the snap need to be? More (kilo)joules, louder bang :)
Myke
Fri Jul 25 2008, 12:54AM
How regular do the pulses need to be? You don't have to use a trigger to trigger the gaps because once one breaks down, the others will break down too. Is this right?
scytheavatar
Fri Jul 25 2008, 03:20AM
I need to produce around 165dB to 200dB of sound relative to 1uPa, which works out to mean a circuit producing somewhere between 200W to 600W of power. The sound doesn't need to be periodic, but preferably there should be a way to control the duration and the magnitude of the sound produced.
teslacoolguy
Fri Jul 25 2008, 04:27AM
I would say that a large discharge capacitor bank with a triggered gap is the way to go.
Dr. Slack
Fri Jul 25 2008, 06:58AM
165dB to 200dB of sound relative to 1uPa ... between 200W to 600W of power
err, show your working. Each "snap" will have a certain energy, so by W do you mean J, or are you assuming a repetition rate?
Once you have a snap from an arc, there's not really a way to control the duration of the sound.
Do you really need the complexity of a Marx? The same energy produces pretty much the same bang from the same heating in the arc, whether from a high voltage or a low voltage discharge, perhaps more from a short low voltage arc than a long high voltage arc. So connecting all your marx caps in parallel with the first stage and triggering that lot ought to be just as good, if not better, than a full marx.
scytheavatar
Fri Jul 25 2008, 08:38AM
Edit: So something like this is more suitable?
Fri Jul 25 2008, 04:16PM
I think that what he means by '600w of power' is that it would take about 600w of power to get a speaker making that much sound.
To generate 200dB of sound pressure using a marx generator will be tricky, I think that you migt be better off using triggerd spark gab. That works by charging a capacitor (you are probably going to need a bank of electrolytic caps series to get about 2kv with about 500-1000j) between 2 large electrodes that are almost close enough for it to spark, but not quite. The you take a 3rd electrode (this one doesn't need to be big) that is connected to a trigger transformer, which could be made with either a flyback transformer or ignition coil with a 5uf/100v poly capacitor that can be connected across the primary by means of your trigger switch).
Fri Jul 25 2008, 10:58PM
A vacuum relay - such as one of those made by Kilovac or Jennings - in the first gap position should do the trick.
scytheavatar
Sun Jul 27 2008, 03:35PM
... wrote ...
So the third electrode is supposed to be somewhere between the spark gap? And I am supposed to create a pulse with the trigger generator?
