  • Guests: 47
OiD (38)
jolty (50)
Baran (29)
10/16 Sanchez (36)
10/16 Knarvel (13)
Useful IGBT Ratings?
aonomus
Sat Jul 26 2008, 12:49AM Print
I'm tempted to buy a batch of IGBTs, they are Toshiba 900V 60A (120A Ipeak for 1ms) IGBTs, would these be useful for flyback drivers/TCs, coilgun/railguns, etc? Its a batch of 20 or so on Ebay (I'm somewhat intentionally fuzzing the details just incase someone tries to scoop the lot of IGBTs), so its very tempting to buy.
It seems like one of the issues with IGBTs for use with TCs is switching time, the IGBT has a switching time under 1us, and for 1ms pulses currents of 100A are fine. Does anyone think this IGBT is too whimpy for this kind of usage? The datasheet on their IGBT series says its good for things like induction heating, UPS inverters, etc. The bid ends soon so any input would be appreciated...
Datasheet
Dr. SSTC
Sat Jul 26 2008, 08:51AM
Dr. SSTC Registered Member #1407 Joined: Fri Mar 21 2008, 07:09AM
they seem usefull, have good rating
i believe you should buy them
never know what you can use them for
when you get bored on the week end build your self a small tesla coil or something
Sat Jul 26 2008, 12:03PM
Meh, the pulse current rating is a little low, but if they're cheap, go for it. If you're new to working with IGBTs they'll make good cannon fodder :)
aonomus
Sat Jul 26 2008, 01:54PM
Since I'd get so many of them cheap, I wouldn't be as afraid of blowing a few, I've never used IGBT's before but I'm familiar with SCRs.
As far as I know a SCR is avalanche based and once you trigger it, voltage must drop below a certain point for current to stop flowing where IGBTs can be turned on and off which means I can shape pulses?
Sat Jul 26 2008, 02:18PM
Yeah, they're basically MOSFETs on steroids.
aonomus
Tue Jul 29 2008, 04:29AM
Bah, some plod outbid me (probably by a darn large amount too given that it went over my bid). Anyone know any good cheap sources for decent IGBTs for H-bridges?
