  • Guests: 42
OiD (38)
jolty (50)
Baran (29)
10/16 Sanchez (36)
10/16 Knarvel (13)
Help calculating the frequency of this timer!
Plasmaarc452
Fri Jul 25 2008, 04:23AM Print
Plasmaarc452 Registered Member #1394 Joined: Sun Mar 16 2008, 06:18PM
Ok I just finished building this 555 flyback driver but now I need to know what what frequency is operates at.
This is the driver
Now here is the formula I used
F = 1/(.693 x C x (R1+R2))
The website I got the formula from was Link2 scroll down to the astable operation and there it is.
I am assuming that the potentiometers are at there max 10k setting.
F = 1/(.693 x .00000001 x (11,000 + 11,000)
I got 6,560 Hz
Can anyone tell me if this is the correct frequency? It does seem kind of low for a flyback but then again the potentiometers were at there max.
Also the duty cycle
Same website but this is the duty cycle formula
D = (R1+R2) / (R1+ 2R2)
I got a 66% duty cycle which seems about right.
I just want to make sure these formulas work for this configuration.
Myke
Fri Jul 25 2008, 05:10AM
Yup, seems right. I think flybacks like low or high duty cycles.you might also want to put some snubber on the mosfet so that the spikes don't kill it. The snubber would be a backwards diode and a cap I think.
Fri Jul 25 2008, 12:07PM
You might consider replacing the IRF510 with IRF540. You might get maybe 4x less heating.
Plasmaarc452
Fri Jul 25 2008, 10:56PM
Thanks for checking, the duty cycle and frequency seemed to be about right but I needed to make sure!
I am going to replace the mosfet and rebuild part of this circuit to make it capable of 36v at 20amps like the zvs driver.
Dr. SSTC
Fri Jul 25 2008, 11:16PM
Dr. SSTC Registered Member #1407 Joined: Fri Mar 21 2008, 07:09AM
Dr. Kilovolt wrote ...
and 3 times longer arcs tongue
