  • Guests: 34
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Eagle PCB, extracting package art without library
ragnar
Wed Jul 23 2008, 12:57PM Print
Greetings,
I have a .brd file with a package I drew, however I have since lost the library. If I use the "Info" tool on the component, it tells me the (former) library it used to belong in, of course, the .lbr is not anywhere on the hard-drive.
Is there any way of extracting the component package? If I use "cut" and "paste" from board to library/package, none of the objects are valid to copy across...
ragnar
Wed Jul 23 2008, 02:09PM
OK, found a solution already, somewhat. The component was a particularly awkward one with mixed metric and imperial dimensions, which is why I wanted to salvage it, but there was no straightforward solution to this.
Here's what I did:
I relocated the component over 0,0; changed to a layer that is common to boards and packages such as TDOCU / TNAMES etc, and then traced over the existing part. It's possible now to "cut" the TDOCU lines and "paste" them into a package, and put pads in.
