  • Guests: 51
High Voltage AC Probe
e.m.c.2
Wed Jul 23 2008, 07:01AM Print
e.m.c.2 Registered Member #835 Joined: Wed Jun 13 2007, 08:46AM
Hello community ,
I am a Italian fan of high tension and would need a council to build a probe for high tensions, I need this for AC high voltage max 200Kv ( yes , 200 Kvolts!) ,freq max 50 Hz.
Some of you has a scheme to be proposed?
I thank everyone in advance,
E.m.c.2
Hazmatt_(The Underdog)
Wed Jul 23 2008, 07:06AM
Here's a nibble and a start for what you're looking for: Link2
quicksilver
Wed Jul 23 2008, 01:21PM
I was building one and then found a commercial model built by RCA back in the 1950's. What I found was that I needed a solid design with a arc ring to protect the hand: which was a major design issue. I also went with a 50M ohm 100W resistor (if the thing is to be fed into a standard DMM) and I was shooting for 50k. I believe you could check for some existing threads on "HV probes" and get a lot of information.
Mine works however. (it has a ground; inter-mixed in design with the probe) which is VERY important. And essentially has it's own little multi-meter for it's use alone. You would be surprised who much design plays an important role in safety and accuracy with an HV probe.
You CAN find them used: but it's lucky to get one inexpensively. Keep reminding yourself of what low frequency, high current, large AC will do and it will keep you conservative in your construction designs smile
