  • Guests: 70
01/13 si2030 (62)
Can you run a transformer backward?
Plasmaarc452
Tue Jul 22 2008, 11:52PM Print
Plasmaarc452 Registered Member #1394 Joined: Sun Mar 16 2008, 06:18PM
This question has been bugging me for a while so here it is.
Can you run a 120v to 12v transformer backward by hooking up the 120v to the secondary and the primary would become the output? That way you could output 1.2kv, There may be insulation problems but I would never take it above 500v so I don't know how much of a problem that would be.
Ken M.
Wed Jul 23 2008, 12:09AM
Of course you can, however I can't guaranteer how long it will last.
Antonio
Wed Jul 23 2008, 12:20AM
The core would saturate. The low-voltage winding doesn't have enough inductance to prevent a huge current coming from the power line, and the formation of a too intense magnetic field in the core. It's not without reason that high-voltage transformers have much more turns than low-voltage transformers.
aonomus
Wed Jul 23 2008, 12:27AM
On a similar train of thought, can a transformer meant for 12v->120v from a inverter be run in reverse to make 12v? Its rated at something like 1.2kVA and its pretty hefty.
Dragon64
Wed Jul 23 2008, 12:51AM
Dragon64 Registered Member #1438 Joined: Sat Apr 12 2008, 12:57AM
How about running a MOT backward, for high current and low voltage PSU
Antonio
Wed Jul 23 2008, 01:11AM
The rule is simple: Don't exceed (by much) the nominal voltage of a winding, when using it as input, or the core saturates. You can connect a 12-127 transformer as 127-12, operating it at the same frequency. Using a MOT backwards (with the high-voltage winding connected to 127 V) would work, but then there is an unnecessarily high number of turns in the windings, and there is a way to make a smaller transformer with smaller losses due to the resistance of the wires.
Plasmaarc452
Wed Jul 23 2008, 01:37AM
What if I current limit how much the transformer can draw, will this prevent the core from being saturated?
Antonio
Wed Jul 23 2008, 02:04AM
Plasmaarc452 wrote ...
Yes, but this will also reduce the input voltage, and the output voltage too.
aonomus
Wed Jul 23 2008, 02:11AM
Its strange how this topic was posted just as I was wondering. I think that with a MOT the HV windings might also cause excessive resistive losses cause of current draw?
Plasmaarc452
Wed Jul 23 2008, 02:38AM
How does current limiting with a resitor reduce voltage? I thought a resistor limited current not voltage. As for input voltage limiting I was thinking that a dimmer switch could be used.
