  • Guests: 44
OiD (38)
jolty (50)
Baran (29)
10/16 Sanchez (36)
10/16 Knarvel (13)
Thermodynamics question . . .
Sat Jul 19 2008, 08:54PM Print
With my wife being away in Europe for 6 weeks with the kids, one night while looking into an almost empty fridge, i began pondering a thermal question.
Assuming the items in the refrigerator are already had the steady state temperature (neglecting energy required to initially cool them), and that thermal leakage is constant (inside to outside) . . .
Does it take more energy to maintain the contents of the refrigerator at the cooling temperature if its completely full vs. almost empty???
aonomus
Sat Jul 19 2008, 10:45PM
I would think if the fridge has a large mass of water-containing food at low temperature, the overall environment inside would be harder to warm up since opening the fridge full means less warm air enters, and therefore less heat.
Sun Jul 20 2008, 08:22PM
The simple answer: The same amount of energy, since the thermal path between fridge and ambient is the only way for heat to flow, and isn't affected by the objects inside it.
(The First Law says that if the objects are at their steady-state temperature, no heat will flow into or out of them, although it might flow through them as it leaks through the fridge walls.)
The complicated answer: The objects inside will block convection currents and insulate the walls, making the thermal leakage less than if the fridge were empty. But this isn't relevant since you specified the leakage to be constant.
cbfull
Mon Jul 21 2008, 12:10PM
I've been studying refrigeration systems for a little over a year now because it's just so cool (okay, you can take or leave the pun).
What everyone has told you so far is correct. Having many thermal masses in the refrigerator provides a large buffer for temperature changes. Also, as Dr. Conner pointed out, they also serve as baffles which stabilize the cold air currents when the door is opened, so the result is less heat flow into the contents.
Curious, are you really asking about the overall power consumption of the compressor in a real system, or just the heat flow in general as defined by thermodynamics?
Mon Jul 21 2008, 01:57PM
Just asking in general. . .
but thanks, you cleared up my question.
