  • Guests: 44
OiD (38)
jolty (50)
Baran (29)
10/16 Sanchez (36)
10/16 Knarvel (13)
High side current sensing
Thomas F
Sat Jul 19 2008, 07:09AM Print
Thomas F Registered Member #503 Joined: Sun Nov 19 2006, 06:37PM
Hi ,
I could do with some help on DC current measurement. I need to measure a current of maximum 300mA which is on a common mode voltage of 30VDC.I was planning to use a 3 - OpAmp differential circuit using OP07.
This does not seem possible now because I find that one of the differential inputs has to be grounded.The ground of the measuring circuit shares the same ground as the current circuit. ( I hope I put that meaninfully.)
Is there any other way to do it without using special ICs from Linear or AD. Google provides mostly links to these.
Can anyone suggest/point to some links which would help me.
Thomas
Sat Jul 19 2008, 01:06PM
Measure it on the return leg of the 30VDC.
Thomas F
Sun Jul 20 2008, 08:47AM
Useful appnote to begin with in case someone needs it.
Well I will try the low side sensing since it looks a bit more simpler.
Sun Jul 20 2008, 08:15PM
What's wrong with special ICs? I stumbled across this article Link2 the other day, which recommends the AD8210. I'm sure you could get samples from Analog.
You could make your diff-amp thing work with a precision voltage divider, or use a sense amp based on a LF411 or TL081, which both have a common-mode input range including their positive supply rail. (I hope you know what common-mode input range means, or you're in for some interesting pitfalls in this application.)
Thomas F
Tue Jul 22 2008, 02:22PM
Well I did not. Now I do :).I am making it based on LF412.
Cheers
