  • Guests: 42
ZVS flyback troubles
Fri Jul 18 2008, 04:49PM Print
Hi
I have build the mazzilli driver and it seems to work, I can get about 40-50kV at as low voltage as 8 Vdc, and it will grow thicker and hotter towards the 40Vdc, it will arc to the ferrit core of the flyback until about 25-30Vdc.
It was when I hooked up the gates to my scope it seemed strange, the gate signals are identical where I was thinking they would be running in each their half period. I have checked the circuit many times and cant find any construction faults.
Attached are pictures of the driver, all components are the ones descriped in the orignal schematics or similar, all checked.
The scope picture is showing both channels, and its set to trigger on channel A, but no matter the trigger settings they are always identical.
1216399779 1403 FT0 Img 1004
1216399779 1403 FT0 Img 1005
1216399779 1403 FT0 Img 1007
Fri Jul 18 2008, 05:10PM
well, if the circuit works as it should then theres probably a problem with your scope setting/bad connection of probes etc. If the signals were identical there would be no voltage on the primary.
GeordieBoy
Fri Jul 18 2008, 05:31PM
Try flicking the Vertical Mode switch from "Dual" to "Chop" and make sure the Trigger Source is selected as Channel A only. Also make sure both scope probe's ground leads are connected to the DC bus negative rail.
Fri Jul 18 2008, 05:55PM
Seems to be troubles with the triggering, if I adjust it for channel A, channel B wont show and vice versa.
There is a switcher for Normal sync and TV sync. each with a positive and negative setting, flickering it between positive and negative seems to show the picture I would like to see, so the problem is unfortunately my old scope :(
never had luck finding a manual for it and very little experience in using one.
both ground leads are connected to negative rail
Fri Jul 18 2008, 05:57PM
Forgot to attach picture of the other half of the scope.
1216403878 1403 FT50163 Img 1009
Antonio
Fri Jul 18 2008, 09:38PM
Did someone ever manage to run a reasonably correct simulation of the Mazzilli driver? A simulation with linear inductances in SwitcherCad III doesn't work well. Maybe it requires core saturation, in the flyback or in the series inductor.
The operation appears to be very sensitive to the series resistance of the power supply. angry
Myke
Fri Jul 18 2008, 10:55PM
Set triggering to NORM and set the input to CH A?
Sat Jul 19 2008, 05:23AM
Antonio wrote ...
I am using a rewound MOT as the supply, full bridge rectified without a smoothening cap, I did not have any that would not heat up too fast.
Myke wrote ...
I have tried all the combinations without any different result than the 2 signals being identical
Sat Jul 19 2008, 05:53AM
Here is a measurement of the AC supply, full wave rectified DC and the two signals together. There is no difference between using dual or chop. Trigger settings where Normal + and channel A.
Seems there is too much internal noise between the channels and it impossible to use both channels at the same time for a reliable result :(
1216446778 1403 FT50163 Img 1011
1216446778 1403 FT50163 Img 1012
1216446778 1403 FT50163 Img 1013
Antonio
Sat Jul 19 2008, 12:55PM
How did you connect both probes to measure the AC input and the full-wave rectified output? If you are using a diode bridge (4 diodes), this is not possible, as the ground is not the same.
A capacitor that heats up quickly? Very strange, as capacitors normally don't dissipate significant energy. Possibly a wrong connection or insufficient voltage rating.
Are the red buttons in the "cal" (calibrated) position?
