  • Guests: 56
Michael Witt (36)
AleSeg (15)
09/17 Jyardana (41)
09/17 Gunboat (72)
09/19 raff (48)
Scanning Laser (obstruction detection).
MScooling
Thu Jul 17 2008, 02:36PM Print
MScooling Registered Member #1016 Joined: Fri Sept 21 2007, 08:46PM
Hey guys,
I work with a machine that has occasional issues with small pieces of scrap steel (about the size of a 10mm crescent wrench) damaging our product as it goes through a water quench. The scrap comes with the product from an upstream robotic plasma cutting process and the control engineers haven't been able to fix the problem.
My initial idea was to use CCD cameras along with NI Vision software to detect scrap in the bed, but the visual variances of the system are making detection difficult. The other idea was to fire a laser down the length of the bed and near the surface. Scrap would break the beam and activate an alarm. The beam would have to be very close to the bottom surface since the scrap material can be as thin as 4.8mm.
Here is a video of the process:
Snapshot
http://filebox.vt.edu/users/sparkman/quench.avi (3.3Meg, Microsoft MPEG4)
This is the target area:
http://filebox.vt.edu/users/sparkman/target_area.jpg
The quench bed is around 50 feet long and is decently flat.
And here are two GIF animations I created to demonstrate the concept.
http://filebox.vt.edu/users/sparkman/laser2.GIF
http://filebox.vt.edu/users/sparkman/laser3.gif (shows beam location and minimum scrap thickness)
I’m looking to see if anyone knows of scanning laser system similar to the concept.
Thanks
Dave47
Thu Jul 17 2008, 04:45PM
Dave47 Registered Member #84 Joined: Thu Feb 09 2006, 01:06PM
The DARPA urban Grand Challenge guys used one of these...
It says its distance accuracy is <2cm, though. I wouldn't know if its sensitivity could be modified for reliable 0.5cm accuracy.
David
Carbon_Rod
Thu Jul 17 2008, 09:13PM
As the above post stated... most Lidars/Ladars do not have sub cm accuracy.
You may find painting the bed or work-material with a fluorescent paint for a vision system easier. In this case pairs of cameras (at 45' and 315') on each side would be needed to cover the blind spots.
OpenCV is often used for high speed detection of edges, shapes, and color clusters.
Thu Jul 17 2008, 09:28PM
Being an electrician (apprentice anyway) and having worked with touchy sensors Im going to say that it would probably be more trouble caused by the laser picking up things other then the debris you are looking for. Would it not be possible to have a brush/sweeper run over the area during part of the machines cycle when it would not be interrupting anything? It would cut down the complexity but it would be larger in size but, unlike a laser it would rarely (if ever) have to be cleaned.
mikeselectricstuff
Thu Jul 17 2008, 10:20PM
I can't play the vid on this PC - does the scrap arrive along with the bar being quenched, or do you want to check for a clean bed first?
If the former, you may have problems with the hot air around the bar causing optical shimmering, messing up any optical sensing.
Might a simple solution be to run a brush or something along the bed? Or some kind of mechanical probe that would detect any obstruction?
As it's metal you're looking for, might an inductive sensor scheme be practical - a number of rectangular coils in the bed ( far enough away from the surrouding metal) - obviously environmental protection of the coils may be an issue.
Is there somewhere a powerful magnet or magnets could be placed to catch any small bits on their way in without affecting the larger product bar?
MScooling
Fri Jul 18 2008, 02:03PM
Here is a bit more information. Our product is essentially a c-channel rail the ranges from 10-40 feet in length. Before the rail enters the furnace, characteristic shapes are cut into the rail with a robotic plasma cutter. Sometimes the the scrap material hangs on to the rail and breaks off when it reaches the quench. It would be ideal to detect this scrap material before the rail entered the furnace, but I don't believe I will see the funding for a system that complex.
Our product enters the quench bed at 1600F. Paint is not going to survive. The bed is made from hardened tool steel, and we replace the bed plates regulary due to wear.
We would only scan periodically, perhaps after 10 or 20 rails go through the quench or whenever there is a gap in production. The rail would be out of the bed when we use the laser to scan for scrap.
If we do purchase a laser/sensor, it will need to have a sensitivity adjustment so it doesn't pick up insignificant objects.
I played around with NI Vision to detect scrap in the bed. Here is what I came up with:
http://filebox.vt.edu/users/sparkman/compare1.gif
http://filebox.vt.edu/users/sparkman/shape_detection.bmp
I was looking at this "laser fence": http://www.mcelasers.com.au/product.php?code=LR.100
If I could mount the LR100 on a frame that moved back and forth, it might get the job done.
Thanks for the ideas.
aonomus
Fri Jul 18 2008, 02:49PM
Why not reverse the detection scheme? Instead of looking for the scrap metal in the trough, scan the rail on its way in to check for a gap where the scrap metal should not be. It might be hard with a camera since the metal is so hot it'l give off a ton of IR, but a laser could check for however many 'holes' there should be?
GeordieBoy
Fri Jul 18 2008, 03:50PM
Have you investigated capacitive proximity sensors like those used on plasma cutting heads to keep the torch the correct distance from the workpiece? Something like that may be able to detect pieces of scrap metal sticking up on the bar as it passes under a sensor.
I can't remember who makes then now, but they work for detecting proximity to conducting material and they work in extremely harsh enviroments. Hence their choice for distance control in plasma apps, where heat, light, acoustic noise, electrical noise and dust contamination are all present.
-Richie,
MScooling
Thu Jul 31 2008, 03:56PM
I got around to mounting a laser level on the quench bed to determine if the concept was worth pursuing.
Here are a few pictures I took:
Setup:
Laser Setup
LINK (1.0meg)
Initial Beam
LINK (1.0meg)
Midpoint down the quench bed:
LINK (1.0meg)
End of quench bed:
LINK (1.0meg)
Past quench bed:
LINK(1.0meg)
The notebook paper is scattering quite a bit of the beam, so the beam appears more diffused than it really is.
Halfway down the bed the beam quality is decent, but by the end it has diffused too much. I'm sure I can find a laser/lense setup that would have a greater distance than the inexpensive test laser.
Anyways, just figured I would update.
mikeselectricstuff
Fri Aug 01 2008, 08:46AM
A helium neon laser will give a well-collimated beam over a decent distance - often available cheap on ebay.
