  • Guests: 45
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
UPS Salvaging
aonomus
Sat Jul 12 2008, 03:39AM Print
Well, for some reason me and some friends have a horrid track record with APC ups's, I have 2x 350VA and 2x 500VA UPS's which I'm salvaging and I'm wondering what I can do with some of the parts....
I have a whole smackload of IRF640s, IRFZ48's, MOV's and PTCs (thermistors that heat up to regulate current), random caps and a few other bits like heatsinks and circuit breakers. A ton of SMD IC's such as logic chips and other waste,
The 350VA models have strange transformers which I have yet to figure out, and both models have SMPS transformers which I don't know how to use....
Any thoughts on what to do with the various transformers and bits?
And even *earlier* I salvaged a old busted amplifier (ok sure there was one bit busted, the monolithic amp chip, but its so old that the parts are worth more than the chip to repair it :/) giving me a ton of various caps and a dual 30VAC transformer.
quicksilver
Sat Jul 12 2008, 02:32PM
Personally I wouldn't tear them all down or at least keep track of what you've got. Many models have a decent inverter that could be the key to other projects, as is. Often (just from my experience) it's the battery that goes. The circuitry is often fine or the charging system is not up to the task.
aonomus
Sat Jul 12 2008, 05:01PM
I already took one of each apart, I could save the other two for their inverters and make my own battery bank. The only bad thing I heard about doing this is that the charger isn't up to the large load and thinks its a dead short by the end of it.
Dago
Sun Jul 13 2008, 08:42AM
Dago Registered Member #538 Joined: Sun Feb 18 2007, 08:33PM
In like 90% of the cases the "broken" UPSs just have a bad battery, by replacing the battery (wont cost much because the batteries are standard lead acid gel batteries) you have a pretty much brand spanking new UPS.
quicksilver
Sun Jul 13 2008, 05:16PM
This is a good example of why I would want more (better) and more test equipment - smile - smile yea!
When it's active you may be able to determine what are the limitations. Thinking wildly, I would imagine that design limitations are that it's made for a shutdown so the whole design is not up to long term output. Shouldn't that be correctable?
aonomus
Sun Jul 13 2008, 06:44PM
I checked the prices of the replacement batteries and at about $60, compared to the $70 I paid for the UPS.... it seems like a counter-intuitive way to spend money.
Tiberius
Mon Jul 14 2008, 04:01PM
Tiberius Registered Member #1484 Joined: Wed May 14 2008, 03:24PM
For the lower end PC / home office UPS systems it really isn't worth it to replace the battery, you can just wait for Staples/Best Buy/etc to have a similar model on sale and obtain a brand new replacement at lower cost than the battery.
A bit off topic, but it makes much more sense to replace the batteries in some of the larger 240V or rackmount models. In my experience these are much more reliable than the home office models, and additionally can offer hours of runtime for a small home office on a fresh battery. I'd recommend shopping for one of these at your local surplus outlets if you need a reliable UPS.
aonomus
Mon Jul 14 2008, 04:26PM
Oh these ones are older ones, the 500VA replaced the 350VA when it kicked the bucket, and my 750VA one (current) replaced the 500VA when it kicked the bucket.
I finally got fed up of seeing a pile of UPS's sit around unused, the inverters inside can be useful since it has the auto-switch circuitry. I can always strap a conventional lead acid onto it (or more sanely, an AGM battery).
