  • Guests: 26
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Surge Arrestor with MOVs
Thu Jul 10 2008, 09:11PM Print
Is making an arrestor simply having one end of a MOV attached to the line and the other to ground? If so, would putting many in parallel increase the surge capacity?
Thu Jul 10 2008, 10:06PM
IamSmooth wrote ...
Yes, they are shunt-mode devices, so you can connect MOVs of the same type in parallel to increase the joules rating and/or life expectancy. As you may know, MOVs become significantly degraded by repeated excess over-voltage, so it wouldn't do to use them for clipping a regular waveform, for example, as you might use a zener diode, because they won't last long.
Thu Jul 10 2008, 10:45PM
What about using them in parallel for lightning protection? I found some at Mouser.com with 70KA surge current ratings. How do I determine what clamping voltage or other parameters I need if this is for lightning protection? Thanks
Here is a link Link2
Fri Jul 11 2008, 07:30PM
The standard MOV let-through voltage for 120V AC working is 330 volts.
MOVs are sometimes used in combination with Gas Discharge Tubes for added protection.
Fri Jul 11 2008, 07:38PM
Everyone that I have spoken with in the Solar industry has said that the MOVs and SOVs may offer some protection, but against a direct hit they don't work. Other than having a lightning rod take the hit and divert the energy, nothing is going to work. Does anyone have any experience with one of these arrestors actually taking the hit and saving the equipment?
EEYORE
Fri Jul 11 2008, 07:40PM
I doubt they would protect from lightning. I believe they are usually used for power surges in the power lines...
Matt
Fri Jul 11 2008, 09:41PM
Well a typical lightning strike would be around 10kA so I don't see why a 70kA MOV would not protect you from lightning. Of course the equipment can be damaged by overvoltage but at least it won't be completely toasted...
Sat Jul 12 2008, 08:36AM
I would distinguish between surge arrestors in general, and lightning arrestors, which are surely a particular class of surge arrestor addressing a very particular problem.
Lightning arrestors can, and often do, involve combinations of air gaps (such as carbon block), gapped equalizers, gas discharge tubes, MOVs, and one-shot fail-safe devices.
There are many detailed descriptions of lightning arrestors in the US Patent literature online.
