  • Guests: 31
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Laptop Batteries as Electric Vehicle Power Source
Bust_A_Cap
Wed Jul 09 2008, 08:02PM Print
Bust_A_Cap Registered Member #1561 Joined: Mon Jun 23 2008, 07:58PM
Alright so I'm sure everyone has heard about how the main problem with electric cars is the fact that the batteries are ridiculously heavy, and they don't store enough power, thus you end up with not very long range electric vehicles. So in response to this, people have started to use lithium ion batteries, problem here is that they have to be very carefully monitored, if you over charge them or put to much current into them, they can quickly get out of control, and fry...or much worse and more likely blow up and catch fire. But probably the biggest problem with Lithium Ion batteries is that they are really expensive and thus amateur's have a hard time piddling around with them and making any sort of advancements with the technology.
So forget the dangers for this second because i'm speaking only in THEORETICAL terms. Would it be possible to hook up straight up laptop batteries, to make a bank, which could be used in a car. For instance hook a bunch of them that are similarly rated in series so that you get a higher voltage and thus more power to the motor. Anyways the few laptop batteries that I've seen have more then just 2 pins on the back, which i imagine wouldn't be to hard to get around, but another thing is that they would be really easy to charge, because you could just hook up the normal laptop battery charger up to each individual battery and have them all charge at the same time.
Anyways let me know what you think, just tossing around ideas in my head.
Bust_A_Cap
Ken M.
Wed Jul 09 2008, 08:23PM
The multiple pins are similar to cell phone batteries, where 2 pins are power and the other two are a "I.D. resistor" this I.D.R tells the power management chip and other power chips some info on the battery, or something like that, read about it breifly in Maxiims engineering booklet they mail out every so often.
Shaun
Wed Jul 09 2008, 08:35PM
Laptop batteries may make it easier to implement, but aren't laptop batteries INCREDIBLY expensive?
quicksilver
Wed Jul 09 2008, 10:03PM
Lithium Ion batteries are a bit expensive at the moment; but they're being used in power tools now quite abundantly. That's a good sign as that industry is getting very competitive and chances are the prices WILL drop!
Carbon_Rod
Wed Jul 09 2008, 10:53PM
Not all lithium batteries are the same:
LiCoO2 3.7V 140mAh/g
LiMnO2 4.0V 100mAh/g
LiFePO4 3.3V 170mAh/g
Li2FePO4F 3.6V 115mAh/g
Although some are used for vehicles... the usable life of Li cells still make them cost prohibitive.
AFAIK the industrial NiMH packs are still dropping in price (IIRC the last price was $8.5k), and companies like Toyota warranty the Prius power pack for many years.
The Biodiesel reactor currently costs consumers $0.63/l if they know were to look. Very few electric vehicles (Honda) can beat the total cost of ownership for a 6 cylinder turbo diesel on D100.
Andyman
Thu Jul 10 2008, 01:15AM
The tesla roadster's battery is basically a trunk full of lithium laptop batteries.
Firnagzen
Thu Jul 10 2008, 09:38AM
Firnagzen Registered Member #567 Joined: Tue Mar 06 2007, 10:55AM
The problem with Li-ion batteries, as I understand it, is that the batteries degrade quite fast, and are considered by the industry unsuable by the time they're three years old. Also, heat causes the degradation to accelerate. Something else... Oh right. [Deviation]That's why I was so annoyed when I heard the iPhone's battery wasn't removable.[/deviation].
Thu Jul 10 2008, 09:54AM
Yeah, the T-Zero did this a couple of years back. It got something like 300 miles on a charge and could still beat a Porsche 911 Turbo down the quarter mile. The Tesla Roadster is basically the powerplant of the T-Zero, with the same 200hp induction motor and inverter, and a similar battery pack, stuffed into a Lotus Elise chassis.
As far as I know, the pack has about 6,000 of the 18650 cells used in laptop packs, connected in series-parallel to deliver 300V at a couple of hundred amps to the inverter. That's a lot of batteries (the average laptop pack has maybe 9 cells) and the main problems, as other posters have pointed out, are the cost, limited lifetime, and the risk of the whole thing "venting with flame" (Li+ battery manufacturers' euphemism for exploding) in a crash.
If you have $20,000 lying around, AC Propulsion will sell you the motor and inverter system that's in the Tesla Roadster. Wrightspeed put it in an Ariel Atom Link2
There's also the Killacycle, a drag racing bike powered by A123 Systems' lithium-ion batteries. They're the exact same ones used in the new DeWalt cordless tools, just a heck of a lot of them.
Sun Jul 20 2008, 05:39AM
For the prototype tesla roadsters they actually bought and cracked open laptop batteries for the cells.
Sun Jul 20 2008, 03:59PM
Hi all. One alternative might be the packs currently being sold for electric drills, these are fairly high energy density and use the huge cells rather than 18650s.
Also, I have found that even broken packs might be useable as the main cause of failure is cell imbalance which results in the controller "bricking".
Regards, -A
