  • Guests: 46
Proud Mary (62)
omegalabs (39)
Plasma Lover (32)
09/16 Michael Witt (36)
09/16 AleSeg (15)
09/17 Jyardana (41)
My first decent size Coil
Andyman
Tue Jul 08 2008, 07:42PM Print
Well, I finally decided to build a "real" coil. All my others have been mini thrown-together coils that barely functioned. I have a 4.5 inch coil that I had wound probably half a year ago that has just been sitting gathering dust. So I wound a primary for it and acquired some capacitors. Anyways, heres the setup.
Power: 9kV 60ma nst graciously donated by Dr. Spark.
Capacitor: Currently, (25) .56uF 1600V CDE caps all in series. I have some other caps that I will experiment with as well.
1215544792 1083 FT1630 P7082507
Primary: I'm temporarily using 10 awg insulated wire for the primary coil. The coil was a huge pain to wind, with all that wire going through the holes. I don't know how some people do it. I have copper tubing, but I'm afraid of running into similar problems and can't figure out the best way to make supports.
1215544792 1083 FT1630 P7082502
Secondary: 4.5 inch outer diameter gray electrical conduit. 956.4 turns of 24awg according to teslamap. I measured the inductance of the coil and played with different winding height values until teslamap came out with the correct inductance. Pic, with toroids attached:
1215544792 1083 FT1630 P7082505
Spark gap: I'm using a segmented copper pipe gap, with an adjustable gap in series for fine tuning of the spacing. The extra gap is quenched by a blower. If I recall correctly, in segmented gaps, if one gap quenches, then the rest do as well. In my configuration, I have the one gap dedicated to quenching and fine tuning.
1215544792 1083 FT1630 P7082508
Right now, I'm getting at most 19" strikes to a grounded target no matter how much tuning I do. According to teslamap, my transformer should be capable of 40" sparks. Any suggestions?
Tue Jul 08 2008, 10:11PM
Andyman wrote ...
A thicker primary will help quite alot. Also you could make a rsg and add a few inches of sparks. If you have bigger sparks at the time you turn it on and then the die down, you are not getting good quenching. I made a rsg with a 3000 rpm scooter motor and using a hole saw and cut out a piece of 5 ply wood. I then got 8 wood screws and screwed them in after making sure the where perfectly placed. I connected all of the screws together with some wire. I got a 2x2 piece of wood and drilled a hole and put a screw through it for a stationary electrode. Did the same for the other side. It works quite well, as you can see on the video of my cruddy 4 inch coil and it works like it should. I get no decrease in performance after 3 minutes of constant running.
Mike
Tue Jul 08 2008, 10:53PM
first thing is go buy 1/4 copper pipe and make a new primary with it. its like 20$ for a 30ft roll
Andyman
Tue Jul 08 2008, 11:48PM
Ok thats what I thought. I have the 1/4 inch copper tubing (50 feet) and I just haven't gotten around to making the supports.
The coils about my size that have such long streamers mostly have static gaps that I have seen. I'm also afraid that the RSG will be too powerful and kill my nst. One thing I can NOT have happen. I already have two candidates for an rsg motor.
Th
The one on the left is a 2500 rpm scooter motor. It says its rated for 14 amps at 24 VDC though, which is quite a bit for dc. The one on the right I got out of an old trashed evaporative cooler. It's a 1725 rpm 3 amp motor and HEAVY.
With my coil though, it actually seems to be worst when it first starts up.
A couple questions:
For NST power factor correction, is any capacitor better than none at all? Does the pfc capacitor improve spark length at all?
For the protection circuit: Does a LC circuit work as well as an RC circuit if the inductance is high enough?
Wed Jul 09 2008, 12:07AM
Andyman wrote ...
Th
First of all, if the nst has a capacitor while using a rsg, it will not harm it. The capacitor basically filters out the spike. And the nst should have a safety gap which would neep it from killing the nst. Also, the motor that i use only uses about 3 amps when i run it. It is rated for 14 amps when under a large load.
teslacoolguy
Wed Jul 09 2008, 03:50AM
WOW lol it looks like we are all using the same motor for our rsg's. Im uaing a 2500rpm 24v 14A motor also for my rsg on "Big Red".
