  • Guests: 69
01/13 si2030 (62)
Flyback question
TheMooseGoesMoo
Sun Jul 06 2008, 06:33PM Print
TheMooseGoesMoo Registered Member #1576 Joined: Sun Jul 06 2008, 12:48AM
I found a flyback yesterday with two pins on the bottom, one of which labeled DC F/B and the other that says AC F/B. What exactly do these pins do?
Sun Jul 06 2008, 06:48PM
Is this old-style flyback with disc secondary or modern all-potted one? If its the old type and the pins are on the secondary, I think one of them will be your HV ground. You can measure this with ohmmeter, assuming your flyback has no diode on output. Just measure resistance between HV output and the pins, the right one should read around 70-700 ohms.
TheMooseGoesMoo
Sun Jul 06 2008, 07:49PM
Its a modern potted one from a projection TV. There is also a pin on the bottom that is labeled HV and one labeled GND. None of the pins show any conductivity to the outputs though.
Sun Jul 06 2008, 08:08PM
TheMooseGoesMoo wrote ...
I think you have a score there cheesey a Rear Projection flyback can take some serious watts of power (there is a vid on youtube with 700 watts).
I think what you have to do is to find a power supply which gives more than 24V DC, hook the negative to your flyback output, hook one of your multimeter probes to the positive, and prod around the bottom of the flyback with your other multimeter probe until you measure some voltage.
Another way is to build a low powered driver and wave the HV output around the bottom flyback pins, and which gives the most corona/longest arc is the one you want to use. I personally don't like this method as it can damage the transformer internally.
TheMooseGoesMoo
Sun Jul 06 2008, 09:09PM
Wow 700 watts? Hooray for dumpster diving amazed
Should I just solder the outputs together?
Mon Jul 07 2008, 07:28AM
you mean the HV output? I prefer to put an alligator clip on the HV lead but if it is relatively long you can just solder it.
Btw here is the flyback vid Link2
aonomus
Mon Jul 07 2008, 07:58AM
Shameless thread pimp: Link2
More importantly, Link2 describes the procedure of hooking up a 24v+ power supply to the flyback to find the HV secondary (it has a high resistance, so you need to push 24v through to get any reading on the other end)
TheMooseGoesMoo
Mon Jul 07 2008, 12:49PM
Dr. Kilovolt wrote ...
Yea, but there are three of them on my flyback.
Mon Jul 07 2008, 12:58PM
Do you know which one was attached to the tubes/which one is thickest/which one seems to emanate from the largest "structure" on the transformer?
Or maybe each tube had its own HV wire from the transformer? In this case you can parallel them.
Of course a picture would be better than 1001 words.
TheMooseGoesMoo
Mon Jul 07 2008, 01:42PM
Each tube had its own HV wire. I can't take a picture at the moment because I seem to have lost the cable to connect it to my computer. angry
Edit: Eh, I followed the instructions, and none of the pins show voltage between 5 and 10, but all the ones that are labeled with things like DC F/B, AC F/B, HV, and GND all show about 15 volts.
