  • Guests: 59
diposable cameras
polop
Mon Jun 23 2008, 03:17PM Print
polop Registered Member #1537 Joined: Thu Jun 12 2008, 06:44PM
hi there,
i have searched all over the web for the circuit diagram of disposable cameras. the goal is to use the transformers to charge a cap bank for a ciol gun but to use multiple transformers all running of of one (high power) transistor to maximise power and to keep it compact. if any one knows of were i can find the schematics of the cameras and or substitute ways to use the transformers to charge caps please send them my way thanks
Mark-H
Mon Jun 23 2008, 03:58PM
Mark-H Registered Member #607 Joined: Tue Mar 27 2007, 10:39AM
I think something like Sams Fotofacts may have them.
I remember seeing ascii style graphics on the web some years back involving a Kodak disposible camera.
Not sure if the two are related, but could be worth a search on Google.
Cheers.
Mark H.
teslacoolguy
Mon Jun 23 2008, 04:10PM
Here this is probably what you are looking for Link2
polop
Mon Jun 23 2008, 05:08PM
hi there i have just tried two of these circuits but there is a problem. when i power the circuit up all it does is make the transistor very hot. i have made the circuit with a high power transistor and only used the charging part of the circuit - any more reliable circuits you know of
DrZoidberg
Mon Jun 23 2008, 08:34PM
DrZoidberg Registered Member #350 Joined: Mon Mar 27 2006, 05:14PM
Why not use a 555 to drive the transistor? There are tons of circuits for that on the net and it works very reliable.
polop
Mon Jun 23 2008, 10:13PM
with the 555 timer i guess you can just set it up to produce square wave pulsed dc - then run that through the primary of the transformer right. im guessing i will have to tune the 555 to get the most efficient output.
- with that setup will it still put out the same voltage as the origioal camera circuit?
Dr. SSTC
Fri Jul 04 2008, 03:37AM
Dr. SSTC Registered Member #1407 Joined: Fri Mar 21 2008, 07:09AM
polop wrote ...
if your gonna go that far how about this
Avi
Fri Jul 04 2008, 07:01AM
polop wrote ...
so how come a Google image search under "circuit diagram of disposable cameras" comes up with at least 2 suitable results on the first page.
DrZoidberg
Sat Jul 05 2008, 08:43PM
polop wrote ...
You can not connect the 555 directly to the primary. You need to put a transistor in between. So the 555 is connected to the base of the transistor and the collector is connected to the primary.
Avi
Mon Jul 07 2008, 02:25PM
a resistor on the base too
