  • Guests: 38
Making Glass
1 2 3 4
Bust_A_Cap
Sat Jun 28 2008, 10:07PM Print
Bust_A_Cap Registered Member #1561 Joined: Mon Jun 23 2008, 07:58PM
So I'm not sure if this is in the right category or not but we'll see. Anyways so I don't know if anyone has seen that movie where they collect the glass that is formed when lighting hits this certain kind of sand in a dessert. Anyways I was thinking that the bolts that come out of a tesla coil or something of that sort could be discharged into a rod in a bucket or the certain sand that makes glass.
would this work?
Hon1nbo
Sat Jun 28 2008, 10:29PM
depends on the heat of the plasma... that is how sand could, if at all, be made into glass in this case: heat (it also happened with the atomic bomb... I have a piece of that glass from the trinity test site...)
but remember, lightning has MUCH more power than a TC... so the results are more power e.g. more heat.
J. Aaron Holmes
Sat Jun 28 2008, 11:07PM
This is actually fun to do with NSTs, pole pigs, or other HV transformers:
1) Get a chunk of cement or cinder block, etc.
2) Soak it in water
3) Apply HV:
Cooking 400
4) Get glass:
Cooked 400
The above example isn't too cool, but I've actually had 1" diameter glowing balls of glass form before. Depends a bit on the medium. Unfortunately I didn't take good pictures of that, but it was with this same cinder block chunk.
Seems like MOTs would be great for this.
Cheers,
Aaron, N7OE
aonomus
Sat Jun 28 2008, 11:34PM
I'd like to see some pole pigs on this, MOT's and NST's are wimpy compared to a pole pig.....
Also, what about a large metal box/bowl as the ground, and a single electrode placed into a bowl full of sand to get potentially interesting 'fractal' like glass patterns.
J. Aaron Holmes
Sun Jun 29 2008, 12:01AM
aonomus wrote ...
Actually, the above was with two 14.7kV pole pigs in series for ~30kV, run at about 5kVA. But I've also had great luck with NSTs and a fine-grained core sample of cement. The above pictures were just not great examples of results, for whatever reason, and I haven't taken many pictures of this process. I'll do it again sometime in the near future and I'm sure I can produce some better evidence.
Cheers,
Aaron, N7OE
nabiul
Sun Jun 29 2008, 06:57AM
nabiul Registered Member #1558 Joined: Sun Jun 22 2008, 08:22PM
There are already better methods for heating stuff up to high temps. If you have the current needed for welding, or a car battery and some serious eye protection, you can arc two graphite electrodes to form a crude graphite arc furnace. The rods are supposed to heat up to something like 5000F, they use it in industrial form to produce steel.
Bust_A_Cap
Sun Jun 29 2008, 03:12PM
that's interesting about the cinder block, is that because the sand in the conrete mixture is the right kind of sand that can be turned into glass?
also I've been trying to find the kind of sand that is necessary for making glass but due to my horrible googling abilities i've only been able to come up with the conclusion that the type of sand doesn't matter...is this true?
nabiul
Sun Jun 29 2008, 04:52PM
Well you have to be careful of what other things are in the sand as well, often you get iron filings which will probably melt/vapourize and contaminate the glass.
J. Aaron Holmes
Sun Jun 29 2008, 05:02PM
Bust_A_Cap wrote ...
I don't know about a "right mixture"; I think commercial glass-sand is as close to 100% quartz as can be obtained through special processing. The glass gotten from the cinder block was rootbeer-colored, and had to be held in front of a very bright light to see any light make it through. There was definitely a lot of "crap" in it! I'm sure some amount of success can be obtained with most sand. But if you care what it looks like, then I'm sure the kind of sand and concentrations of various minerals in it (e.g., quartz) definitely do matter a lot!
Cheers,
Aaron, N7OE
Sun Jun 29 2008, 05:46PM
I used dry sand and a 4mot stack with resonant caps. Heres a video and photos of what I got.
1214761605 53 FT48673 Fulg1
1214761605 53 FT48673 Fulgerite1
