  • Guests: 25
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
Induction Heating
ahron11
Fri Jul 04 2008, 11:50PM Print
ahron11 Registered Member #1572 Joined: Fri Jul 04 2008, 11:14PM
Hello, I was just wondering if there is a way to make an induction heater with 2 microwave transformers and 2 capacitors? It would be nice if I did not have to go out and purchase more electronics to make this because most of the money I have is going into my 3kj coilgun. Any information you have is greatly appreciated.
Fri Jul 04 2008, 11:55PM
No. Microwave capacitors are rated for dc only and if you use them with ac they will explode and leak. Also, induction heaters use around 300khz or something like that. I have read that someone used a simple 555 oscillator and fet and got good results. He used a few tens of turns for the coil and something like 50 volts..
Sat Jul 05 2008, 12:37AM
Microwave capacitors are made for DC and AC, but these capacitors are not suited for induction heating, if you're going to make an induction heater I think you should read Richie's page about induction heater and try some of that.
ahron11
Actually, microwave capacitors are meant to function of AC.
Shaun
Sat Jul 05 2008, 02:09AM
Yes, they are used for AC, but remember you are talking about 50/60Hz AC at under 1A RMS. For an induction heater you will be using many 10s of kHz at orders of magnitude more current.
