  • Guests: 55
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
cockroft-walton problems
Solidacid
Thu Jul 03 2008, 06:50AM Print
Solidacid Registered Member #1430 Joined: Sun Apr 06 2008, 11:12AM
i just played around with my new 6 stage cockroft walton for a while and noticed something strange.
when i feed it 7,5V AC (50-60Hz) i get 36 volts witch drop drops to 31 over a few seconds.
the strange thing is, when i feed it 12V (also 50-60Hz) it gives off 31 volts from the start and stays there.
how can i get a lower/same voltage when i feed it more?
im using 50v 22uf capacitors and 1000v diodes
im getting 31 volts out with a 12v input should't it be 768 volts?
even at 24 volts in im still getting 31 volts
Fri Jul 04 2008, 04:11AM
Solidacid wrote ...
Problem aside, if you have a 6-stage CW multiplier, if you put 12VAC input, you should only get 72VAC output. Not sure where you get 768 volts from?
Plus 22uF is a lot of capacitance. I'm willing to bet you don't have enough input power to charge / discharge those 22uF capacitors every cycle, so you're only getting a small voltage on each of them.
In Summary, the best output you'll get in ideal situations is 72V with 12V input.
Solidacid
Sun Jul 06 2008, 08:25AM
72VAC?
i though each stage multiplied the voltage by 2,
so with 12V in, the first stage would give 24, the second 48 and so on.
guess i was wrong tongue
