  • Guests: 37
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Active/delayed pull down gate drive
Tue Jul 01 2008, 09:03AM Print
I'm designing a current fed inverter where cross-conduction of switching transistors is a must, but it should be only in the tens of ns range.
I want to drive the transistors with GDT, I can leave pull-up to diodes but I need some kind of active, delayed pulldown, prefferably with just 1 transistor and few passive components.
I saw one thread on this subject here but the links to schematics in it are no longer working.
Any ideas?
GeordieBoy
Tue Jul 01 2008, 09:57AM
If you only need a few 10's of ns of conduction overlap just use RCD "slow-down" circuits on the secondary windings of the GDT to slow down the turn-off edge of the drive waveform.
You will find that typical power MOSFETs like the IRFP460A have a longer turn-off delay than turn-on delay anyway when the gate resistance is small.
