  • Guests: 34
OiD (38)
jolty (50)
Baran (29)
10/16 Sanchez (36)
10/16 Knarvel (13)
variac hookup
teslacoolguy
Sat Jun 28 2008, 03:53AM Print
As some of you know and have read my projects thread about the very big variac i scored i now have some questions concerning how to hook it up. I am assuming that i use the primary neutral as the secondary neutrall but im not sure how i hook everything up the the parallaling choke. Here is a pic so maybe some of you can give me some help on how to hook this monster up.
1214625011 1107 FT0 Variac Hookup
The choke is in that black box mounted to the bottom variac.
Tiberius
Mon Jun 30 2008, 03:17AM
Tiberius Registered Member #1484 Joined: Wed May 14 2008, 03:24PM
It should be connected between the output (brush) terminals of the two units, from what I understand.
even better
teslacoolguy
Wed Jul 30 2008, 12:15AM
Ok i have one more question. I have decided that i am going to run the coil with 240v. I am planning on using 1 variac for each 120v pole and leave out the choke and have a completely common ground. Am i doing this right or not? Tell me what you think.
