  • Guests: 40
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Zener diode capacitance
Fri Jun 27 2008, 07:29PM Print
What would be a "ballpark" capacitance of a lets say, 5V 0.5W zener diode?
GeordieBoy
Fri Jun 27 2008, 08:06PM
something in the picofarads range, and it will probably decrease as you apply reverse voltage and a depletion region forms.
Fri Jun 27 2008, 08:08PM
around 100pF
e.g. Link2
Fri Jun 27 2008, 08:11PM
Sulaiman wrote ...
around 100pF
thanks.
100pF? that's not nice. I was hoping for less than 10pF, I'll probably have to redesign my circuit then.
Firefox
Fri Jun 27 2008, 10:07PM
Firefox Registered Member #1389 Joined: Thu Mar 13 2008, 12:50AM
You could probably reduce it by using a higher wattage zener, thereby spreading the 'plates' apart more and lowering the capacitance. Also, you could perhaps use lower voltage zeners and series them to reduce the capacitance.
Sat Jun 28 2008, 05:42AM
Click on the link that I gave above and on page 3 you will see a graph of capacitance vs. zener voltage.
I'm building a 20m (14MHz) transceiver at the moment
and fine tuning is by using a 39V zener as a varicap for the 3MHz vfo.
