  • Guests: 34
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Quick voltage doubler question
Myke
Fri Jun 27 2008, 04:17AM Print
Hi, I'm wondering what were the connections for a voltage doubler that used just a bridge rectifier and two caps. I have made it before, I just can't find the connections I am supposed to make anymore.
quicksilver
Fri Jun 27 2008, 03:26PM
I would like to "piggy-back" that question with another about voltage/current rating. I would imagine that the current of a rectifier or diode could be kept low but what of the voltage level? If one were using some 15Kv caps would the diodes need similar rating?
Tom540
Fri Jun 27 2008, 05:18PM
Tom540 Banned on 3/17/2009.
put the two caps in series, connect positive out from bridge to positive of the series caps, negative to the negative side of the series caps and then connect a wire from AC in to the middle of the two series caps.
GeordieBoy
Fri Jun 27 2008, 07:24PM
These links show the "switch enabled" or "jumpered" voltage doubler configuration typically used in switched-mode PSUs.
-Richie,
Myke
Fri Jun 27 2008, 11:34PM
Ah, thanks a lot. smile
