  • Guests: 42
williamn (48)
ReddyK (57)
Birdman (31)
12/14 M.A.D. (32)
12/15 marko666 (58)
12/16 Will T (16)
Solar Power Ideas
Bust_A_Cap
Fri Jun 27 2008, 02:28AM Print
Bust_A_Cap Registered Member #1561 Joined: Mon Jun 23 2008, 07:58PM
So I'm working at a company that is using capacitors as a storage unit, like for batteries for electric or hybrid cars, the reason being is that they have a longer pack life. So I was thinking could you use a pack of capacitors as your storage unit for solar power. Have the solar panels charge the cap bank instead of a battery bank.
Hon1nbo
Fri Jun 27 2008, 02:42AM
you could, but there are design considerations such as charge voltage (super-caps, which I would assume you would use, operate at a lower voltage)
aonomus
Fri Jun 27 2008, 02:51AM
I have no idea what kind of storage capacity the supercaps have relative to actual loads, so this might be unrealistic. What about using solar panels (roof mounted) to feed a large cap bank which can be connected to mobile supercap banks on golf carts? Relatively speaking it would allow for fast recharging cheap since currently they sit for a fair while to recharge.
Bjørn
Fri Jun 27 2008, 04:30AM
It would work if you got the capacitors for free, if not they are too expensive for most applications. The capacitors are also less efficient than lithium batteries so you would need more solar panels to get the same power.
Let us think about the golf cart for a minute. If you want 1 kW/h stored. That means ((1000*3600)/7290) = 494 capacitors of 2.7V, 2000F. That is $36 750 on ebay,
A random lithium battery from ebay gives (1000*3600/51948) = 70 batteries of of 11.1V, 1.3 Ah. That is $1050,
7.5 kg of batteries
200 kg of capacitors
You still need to add more capacitors to make up for the lower efficiency and increased weight. If we go down to the same price and weight the capacitors will only last 2 minutes instead of one hour. Charging is not a lot better for capacitors at the same energy either, in this case the batteries can safely be charged in 2 minutes to the same energy as the capacitors. Modern high power batteries may be charged to the same energy in 30 seconds.
It is very difficult to find an application where capacitors are clearly better if you have to pay for them. Even with applications that require many charge/discharge cycles. Because at the same price you can get so many lithium batteries that you can keep them cool at 40% charge and only cycle them a few percent so they will last almost forever.
In cases where you need very rapid charge and discharge the capacitors would be better.
Fri Jun 27 2008, 06:20AM
I did recall reading about "zero voltage" switching MOSFETs which will actually conduct with virtually no applied voltage between drain and source. These would be ideal for a switching supply using low voltage capacitor arrays, you just increase the pulse width linearly as the voltage drops.
Fri Jun 27 2008, 09:17AM
All MOSFETs are like that. They just look like a resistor, of value Rds(on), when they're turned on.
Sat Jun 28 2008, 04:54PM
look up beam robotics. most beam robots use super caps.
