  • Guests: 38
Identifying flyback pins for a 2n3055 based driver (other than HV/primary)
aonomus
Thu Jun 26 2008, 05:43AM Print
I've been toying with a flyback transformer today and I figured out which pins are the HV/ground and primary pins from a few guides/posts. The question I have is which pin do I use for feedback when building a 2n3055 or similar based driver? Most of the pins all read 0-1ohm across each other so I can't seem to figure out which is which, can I use a LCR meter (whose batteries need replacing as I write this thread)?
This is going to be my first foray into HV (I don't think 300V + coilgun counts?), and after reading this guide I'm going to substitute the 2n3055 for a beefier transistor, possibly expanding to a push-pull just for kicks
1214457952 1497 FT0 Flyback Test
1214457952 1497 FT0 Flyback Pins
The 42v brackets indicate the peak reading I got when sending 9v across those pins, forgive the poor drawing.
Also I looked at the pinout found in this thread which seems to somewhat match my flyback (picture below).
1145644628 103 FT0 Pinout2
Note: the guide here describes a better way of determining flyback HV secondary by passing 20-24v through various pins until the voltage reads low (due to resistance of the secondary). This seems better than letting the HV arc to the pins, maybe it should be added to the wiki?
[Edit: Image size]
Coronafix
Thu Jun 26 2008, 09:42AM
Wind some turns (insulated wire) on the actual core for the feedback.
Shaun
Thu Jun 26 2008, 05:32PM
You can use the original primary coil potted in the flyback, but it was meant for like 150V I think, and therefore has far too many turns. You will only get like 1mm sparks with the 2n3055 driver using the original primary.
Coronafix is right, use the exposed core for your windings. You have no idea how long it took me to figure this out; nearly every site on flybacks says either "DC flybacks are useless" or suggests an insanely complex driver that doesn't do much at all.
rp181
Thu Jun 26 2008, 06:26PM
I think his is like mine, theres barrely any space between the core and potting, only thin wire can be used.
aonomus
Thu Jun 26 2008, 08:54PM
This flyback has a comfortable amount of space between the casing and the core, enough to make my own primary windings with decent sized wire. The core is held together by a metal spring, and epoxy. There is a very small gap between the core halves, will this affect making the windings, and if so which side would I want to put them on?
1214513508 1497 FT48381 Flyback Core
1214513508 1497 FT48381 Flyback Core2
Thu Jun 26 2008, 09:15PM
Put the windings anywhere on the core. The gap is needed if you operate it with single-ended driver (single switch). If you make your own windings they have two advantages:
1) if they burn you can rewind them
2) primary winding opposite secondary is better as it limits output short-circuit current more and makes your transistor run more happy.
aonomus
Thu Jun 26 2008, 09:32PM
Just another question too, if I connect the circuit to my benchtop power supply (a commercial one, brand new too) is there any risk of back-emf frying it? Should I put big beefy protection diodes on the 0v and + connections?
Thu Jun 26 2008, 10:35PM
aonomus wrote ...
Yes, high voltage could get into the power supply and ruin the rectifier or the capacitor if there is one.
Fri Jun 27 2008, 10:37AM
aonomus wrote ...
Put a big (several 1000s of uF) filter capacitor across your PSU in parallel with a low-ESR film or foil type cap, in the 0.1-1uF range. This should get rid of all and any voltage spikes.
aonomus
Fri Jun 27 2008, 08:57PM
Wait, a several 1000 uF lytic + a low-ESR/foil type cap?
