  • Guests: 48
12v -> 400v inverter for caps charge
[RUS]ChaosSorcerer
Wed Jun 11 2008, 09:01PM Print
[RUS]ChaosSorcerer Registered Member #1534 Joined: Wed Jun 11 2008, 08:37PM
Hi all)
...and sorry for bad english
I am experimenting with electrothermal gun(It is bases on underwater bang-spark from big caps) And I need to charge caps. Usually I use flayback-type inverter 30-40 watts, but flyback's are freakin weak and non effective (efficency ~70-80%). So I want to make a forward or push-pull inverter. But they 're much more sensitive to overload or shortcut.
But weilding inverters are all built on forward topologies - there used recuperation and PWM. So what better for caps charging and arc making: push-pull or single fet forward with recuperation solenoid?
GeordieBoy
Wed Jun 11 2008, 09:18PM
A well designed flyback converter (isolated buck-boost) is hard to beat if you only want to charge a capacitor to 400v at 30-40 J/s. Peak current mode control with one of the standard Unitrode chips would be my method of choice.
[RUS]ChaosSorcerer
Wed Jun 11 2008, 09:40PM
I just using such device based on uc3845. It is simple but only simple. I want to make is smaller, more effective, more powerful and able for arcing, burning and fun like that))
So I want to make an invertor like welding device but up-step.
Some people say that flyback is immune to shortcut but of course it is not true. With small resistance secondary coil current doesn't let core to demagnetize. When building a forward you can use back-turn to demagnetize the core, but it is still need to watch forward-turn current.
kaboooom2000uk
Fri Jun 20 2008, 06:10PM
kaboooom2000uk Registered Member #324 Joined: Thu Mar 16 2006, 10:28PM
This depends upon your experience, but id like to suggest a simple halfbridge or as sugested, a push pull type system. Id also suggest to use IGBTs for their robustness, and high current capacity.
otherwise save youself the components and design a boost converter. These are quite reliable, and just set the duty cycle of the positive pulse to a minimum to allow for shorting tollerance or power limiting. or if your fancy you could even add an extra op-amp to measure the voltage across a current shunt and have the output set as a refererance in a comparator so it controls the duty cycle for you in realtime.
If its any help, i shall post a free circuit you can modify or make. the outputs from device A and B give signals to dive a halfbrige optocouple, or a push pull GDT. You can even just use one of the channels if you want, and freq is controled by the 1nF C1 capacitor.
You will need to place a variable resitor at the voltage divider r10 and r11. This controls the offset so the two output op-amps compair a refernce to the AC triangle wave. Channel generation in essance uses the positive cycle to generate A, and the negative cycle to generate B, crude, but effective as it gives you all the deadtime you need.
then hook this upto a opto driver for your igbt or mosfet, and you can create an efficent HF transformer driver. or welder or whatever, the possibilites are endless with simple modifications.
hope it helps, only downside it needs a dual supply. Or just use a neat dc-dc converter to overcome this.
1213985428 324 FT47124 Inverter
GeordieBoy
Sat Jun 21 2008, 04:21PM
I personally wouldn't recommend using that circuit to control power electronics as it doesn't have any hysteresis built into the comparators or any latching to prevent double edges on the PWM outputs.
teslacoolguy
Sun Jun 22 2008, 05:41AM
For this application i would reccomend uzzors boost converter Link2 because it is a simple circut and very effective.
lamazoid
Mon Jun 23 2008, 05:13PM
lamazoid Registered Member #573 Joined: Fri Mar 09 2007, 11:26AM
Тебе скока ватт то надо?
вот тут как раз обсуждаем эту еботню
polop
Mon Jun 23 2008, 06:00PM
polop Registered Member #1537 Joined: Thu Jun 12 2008, 06:44PM
in the schematic tesla cool guy suggested is the hardcore mosfet nessesary if i am only going to use photo flash caps (up to 20 of them). also what is the joule per second as it stands (only need a rough guess)
Mon Jun 23 2008, 11:32PM
You can get away with a smaller mosfet, but the efficiency will go down. Just make sure that it has a ds rating of at least 500v.
Also, 1 joule per second is the same thing as one watt it just makes sense to call them j/s when you are charging capacitors.
polop
Tue Jun 24 2008, 10:03PM
presumable it charges at 300-400v and the rating on that mosfet is 14A so it will be working under that threashhold (say 10 amps) 300 * 10 = 3000w that cant be right can some one help me inderstand the power of the circuit?
