  • Guests: 57
marko666 (58)
12/16 Will T (16)
12/16 william L (29)
12/16 Tipiment (62)
3000 Cap MMC charged by 400kv Van De Graff Generator
Dr. Drone
Sat Mar 18 2006, 11:41PM Print
shades
Sun Mar 19 2006, 12:09AM
Guessing that you will have about a kilo-Joule at say 750 kV
Sounds incredibly scary !
Dr. Drone
Sun Mar 19 2006, 02:17AM
shades
GimpyJoe
Sun Mar 19 2006, 02:25AM
amazed wow! I wonder what kind of electromagnetic nastiness would be generated with that... I'm guessing all the caps will be under oil or the corona would make them impossible to charge?
Michael W.
Sun Mar 19 2006, 03:04AM
Michael W. Registered Member #50 Joined: Thu Feb 09 2006, 04:07AM
So do I really want to know how you aquired 3000 doorknob caps? cheesey
Dr. Drone
Sun Mar 19 2006, 03:17AM
shades
Self Defenestrate
Sun Mar 19 2006, 03:37AM
Self Defenestrate Registered Member #87 Joined: Thu Feb 09 2006, 01:36PM
So whats the breakdown of those strings, how many caps per string by x strings paralel?
Alex
Sun Mar 19 2006, 04:00AM
Alex Geometrically Frustrated
Registered Member #6 Joined: Thu Feb 02 2006, 04:18AM
A Van De Graff generator puts out very little current, probably in the microamp range, so it's not going to make a very good power supply for a marx (it'll leak off the voltage before it's anywhere near charged).
However, that doesn't mean you can't build your marx. Instead of using a 400kv VDG, you ought to use something that can source a bit more current, albeit at a lower voltage, like a neon sign transformer. You'll need to rectify the output though. Luckily, you can do this with a voltage doubler, and as an added bonus, doubling the output will put you closer to the maximum ratings of your capacitors.
Dr. Drone
Sun Mar 19 2006, 04:57AM
shades
